[Swift-devel] Question about caching
Mihael Hategan
hategan at mcs.anl.gov
Mon Jan 14 19:00:59 CST 2013
There is no caching at the coaster level at this time, and if you use
provider staging, swift doesn't do any caching either, so no.
Mihael
On Mon, 2013-01-14 at 16:54 -0600, David Kelly wrote:
> I am working with an application that uses coaster provider staging to stage files. One of the files, common.tar.gz, gets passed to every app call. Does this file actually get transferred once per task, or does each instance of worker.pl keep a cached copy of common.tar.gz on the node?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
