[Swift-devel] 0.95 RC1
David Kelly davidk at ci.uchicago.edu
Thu Dec 5 12:56:18 CST 2013
Below is the to-do list for a 0.95 release:
   - Bug #1139 - issue with not being able to run on OSG in trunk
   - Renaming of coaster configuration properties ( http://goo.gl/wIbcam )
   - A foreachworker script that executes commands on all coaster workers (
   http://goo.gl/5YuPP0 )
   - Growing and shrinking of pools with persistent coasters
   - Merge site guide and userguide
   - Document new configuration settings in userguide
   - Better error handling of provider failures
   - Automated testing of 0.95
   - Release notes
   - Deploy modules
   - Write a test for Mihael's "install things from a tar file" mechanism
   - Yadu's batch mapping
   - Make the debug info in the info log more useful (make the deafult log
   level quieter, less noise)
On Mon, Dec 2, 2013 at 2:24 PM, David Kelly <davidk at ci.uchicago.edu> wrote:
> Hello,
> I've created an 0.95 branch and a first release candidate. The paths are:
> svn co https://svn.code.sf.net/p/cogkit/svn/branches/4.1.11/src/cog
> svn co https://svn.ci.uchicago.edu/svn/vdl2/branches/release-0.95 swift
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20131205/74ae2d10/attachment.html>
