[Swift-devel] Bugs related to execution providers
David Kelly
davidk at ci.uchicago.edu
Fri Aug 30 16:39:32 CDT 2013
Hello,
I've put together this list of bugzilla bugs related to execution providers and assigned them to myself. I'm not sure yet how many of these are still issues. Some are very old and need to be tested.
133 - PBS walltime violation poor reporting
138 - Spaces in filenames sometimes don't work right with GRAM2+Condor
210 - Job exceeding wallclock limit -- error is not reported by swift
224 - PBS job submission fails when maxnodes greater than queue limit
227 - Always keep submit and stdout/err files for failing jobs from localscheduler provider
327 - PBS job name
409 - Clean up stack dump on manageable qsub errors
453 - Swift accepts bad sites parameters without warning to user591 - Bad project in PBS-coaster sites file causes swift to hang with no message to user
620 - On ranger, jobs are not cancelled after Swift run is killed682 - Make location and naming of execution provider logs and scripts more manageable flexible
740 - Swift continues if the project you specify has no allocation
746 - Cobalt provider on Eureka only uses 8 cores in multi-node jobs
758 - Cobalt provider on Eureka fails silently if user project is invalid
776 - Swift waits on failed job with no messages to user
778 - With status.mode=file, app non-zero exit code is returned as success
979 - Runtime errors in SLURM provider are not halting run and getting sent to user
992 - Allow user defined settings in SGE provider
1010 - Condor jobs linger in C state after completing successfully
1016 - Slurm options from sites definitions does not make into job def using gt2 provider1044 - PBS provider generates incorrect submit file directives for coaster worker logging
1054 - Implement retry around local scheduler commands
1060 - Add option to condor provider to save condor logs
Are there any other known issues that are not represented here? Please let me know. Thanks!
David
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130830/413f4095/attachment.html>
