[Swift-devel] turning off Swift's data caching
Ketan Maheshwari ketancmaheshwari at gmail.com
Sun Apr 21 00:26:44 CDT 2013
I am trying to mimic a scenario where an external process is streaming data
into a file which is being captured at same or lesser frequency by updating
a file periodically which is then cat'ed by Swift into an output file.
The Swift script is the catsnsleep with a sleep of 10sec followed by cat of
input data. Another process running at a slightly higher frequency does
update on the data by echoing random numbers to the data file.
>From the experiments so far, it looks like Swift caches the data file and
uses it for all app calls.
So far, I tried:
1) using external variable type for input data
2) setting caching.algorithm=none in config
Neither of the above seem to work. I think, if I could map external type to
a disc file, this might work.
Any other ideas to turn off input data caching by Swift?
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130421/b1c980c7/attachment.html>
