[Swift-devel] Need help to enable provenance
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Apr 13 15:24:35 CDT 2013
I did a quick test with 0.94 and if I set provenance.log=true, I get
<project><!-- CACHE ID 96e6bf28-7380-4179-918a-e0870ff91fac-provenance
So I'm not quite sure what's happening in your case. I would check
simple things like making sure you are editing the right configuration
file, that you are not overriding -provenance.log on the command line,
etc.
Posting the log might help.
Mihael
On Sat, 2013-04-13 at 12:13 -0500, Michael Wilde wrote:
> Hi All,
> I cant get provenance enabled in either trunk or the head revision of 0.94. Can anyone help me with this?
> Ive got the necessary log4j entries set, and have provenence.log=true in my -config file.
> But my .kml files start off with:
> <project><!-- CACHE ID 9758efb2-4acb-4116-8bd8-e71f9dfd962c-no-provenance -->
> I last had this working with this swift:
> Swift trunk swift-r6171 cog-r3560 (cog modified locally)
> Two questions:
> - has anyone specifically disabled provenance?
> - where is the .kml comment line above coming from? (Im tracking it down now)
> Can anyone provide some guidance on enabling provenance logging?
> Specifically, Im looking for lines like this in the .log file with the provenanceid attribute set:
> catsn-20130129-1033-sgtqveud.log:2013-01-29 10:33:26,978-0600 INFO  swift PARAM thread=0-3-6-1 direction=input variable=i provenanceid=dataset:20130129-1033-gxhdq72d:720000000038
> Thanks,
> - Mike
