[Swift-devel] readData from file array
Ketan Maheshwari
ketancmaheshwari at gmail.com
Wed Apr 3 21:06:43 CDT 2013
Trying to use the readData method on array of files into variables seems to
be failing. Following is an example reproducing the failure:
$ cat test2.swift
type file;
app (file _out) genrand(){
rand stdout=@_out;
file out[]<simple_mapper; location="outdir", prefix="o", suffix=".out" > ;
int val[];
foreach i in [0:9]{
out[i]=genrand();
val[i]=readData(out[i]);
App rand is mapped to a simple random number generator:
$ cat rand.sh
#!/bin/bash
echo $RANDOM
The error message I get on running this is:
Could not start execution
Failed to convert .swiftx to .kml for test2.swift
no such attribute: partialClose in template context [callInternal]
I tested readData on scalars which is working ok. Also, if I remove the
readData line, the script behaves ok.
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130403/b907e1da/attachment.html>
