[Swift-devel] cache already contains error
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Apr  2 10:04:06 CDT 2013
When we both have time, lets look at the failing run(s) more closely.  Im curious whats causing the pattern of failing after 35 app calls.
Im also interested in learning how to alleviate any NFS-aggravated shared filesystem problems.
- Mike
----- Original Message -----
> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Tuesday, April 2, 2013 9:43:19 AM
> Subject: Re: [Swift-devel] cache already contains error
> Hi Mike,
> It works with provider staging. So, it does look like an NFS sync
> issue.
> Thanks,
> Ketan
> On Mon, Apr 1, 2013 at 10:20 PM, Michael Wilde < wilde at mcs.anl.gov >
> wrote:
> Ketan,
> Can you post a pointer to your code, the Swift log, and the Swift
> stdout/err?
> How are you mapping the file "...outdir/out_l0000_0000.0010.out"?
> Does 35 correspond to any of the array bounds?
> Does it fail if you use only one host? (I.e. my first thought was
> some kind of NSF sync error).
> Could you try it using local disk and provider staging with the N
> hosts?
> - Mike
> > From: "Ketan Maheshwari" < ketancmaheshwari at gmail.com >
> > To: "Michael Wilde" < wilde at mcs.anl.gov >
> > Cc: "Swift Devel" < swift-devel at ci.uchicago.edu >
> > Sent: Monday, April 1, 2013 9:02:24 PM
> > Thanks Mike, that fixed the cache issue. However, now I am seeing
> > an
> > unusual behavior from my Swift run:
> > The ampl run crashes after completing a fixed number of jobs (35 to
> > be precise).
> > Some diagnostics:
> > -- It runs to completion when I do a Swift resume. Once again only
> > the next 35 jobs complete successfully. On a next resume the rest
> > of
> > them complete.
> > -- Runs outside of Swift with a bash for-loop using the same
> > parameters as in Swift script.
> > -- A catsn script of similar parameters runs to completion without
> > any failures. So, nothing seem to be wrong with the OS parameters.
> > I am using a single MCS workstation, no provider staging, no
> > coasters.
> > The error message is:
> > Caused by: File not found:
> > /nfs2/ketan/powergridapps/swiftscripts/swift.work/inference-20130401-2043-78i7o5m3/shared/outdir/out_l0000_0000.0010.out
> > Which is reflected in the logs as well as in the workdir's info
> > files.
> > Has anyone seen this kind of behavior? Any remedial suggestions?
> > Thanks,
> > Ketan
> > On Mon, Apr 1, 2013 at 5:59 PM, Michael Wilde < wilde at mcs.anl.gov >
> > wrote:
> > I think you need to make out 2-dimensional.
> > Your script is going to evaluate "out[j] = cat(data)" for both i=0
> > and i=1.
> > The second of those evaluations is probably encountering the "cache
> > already contains" for j=0.
> > If it didnt hit that (ie if you used the concurrent mapper) you'd
> > likely then get an error that out[0] is already set.
> > - Mike
> > > To: "Swift Devel" < swift-devel at ci.uchicago.edu >
> > > Sent: Monday, April 1, 2013 5:49:36 PM
> > > Subject: [Swift-devel] cache already contains error
> > > Hi,
> > > I am running into the "cache already contains" error when using a
> > > nested loop with file mappers. Here is a simple reproduction of
> > > the
> > > issue with a nested loop variant of catsn.swift:
> > > type file;
> > > app (file o) cat (file i){
> > > cat @i stdout=@o;
> > > #file out[];
> > > #file out[]<concurrent_mapper; location="outdir",
> > > prefix="f.",suffix=".out">;
> > > file out[]<simple_mapper; location="outdir",
> > > foreach i in [0:1] {
> > > foreach j in [0:1]{
> > > file data<"data.txt">;
> > > out[j] = cat(data);
> > > It runs into the cache error after completing few tasks
> > > successfully:
> > > $ swift catsn.swift
> > > Swift trunk swift-r6410 cog-r3648
> > > RunID: 20130401-1745-7khkyrqc
> > > Progress: time: Mon, 01 Apr 2013 17:45:59 -0500
> > > Progress: time: Mon, 01 Apr 2013 17:46:00 -0500 Selecting site:1
> > > Active:1 Finished successfully:2
> > > Execution failed:
> > > Exception in cat:
> > > Arguments: [data.txt]
> > > Host: localhost
> > > Directory: catsn-20130401-1745-7khkyrqc/jobs/y/cat-yzf9fg7l
> > > Caused by:
> > > The cache already contains
> > > localhost:catsn-20130401-1745-7khkyrqc/shared/outdir/f.0000.out.
> > > cat, catsn.swift, line 14
> > > The cause, I think is that the nested loop triggers the same
> > > series
> > > of random sequences in mappers code which collides. Both, the
> > > simple
> > > and the concurrent mappers fail with same message.
> > > Does anyone know of a workaround?
> > > Thanks,
> > > Ketan
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > Ketan
> Ketan
