[Swift-devel] cache already contains error
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Apr  1 17:59:15 CDT 2013
I think you need to make out 2-dimensional.
Your script is going to evaluate "out[j] = cat(data)" for both i=0 and i=1.
The second of those evaluations is probably encountering the "cache already contains" for j=0.
If it didnt hit that (ie if you used the concurrent mapper) you'd likely then get an error that out[0] is already set.
- Mike
----- Original Message -----
> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Monday, April 1, 2013 5:49:36 PM
> Subject: [Swift-devel] cache already contains error
> Hi,
> I am running into the "cache already contains" error when using a
> nested loop with file mappers. Here is a simple reproduction of the
> issue with a nested loop variant of catsn.swift:
> type file;
> app (file o) cat (file i){
> cat @i stdout=@o;
> #file out[];
> #file out[]<concurrent_mapper; location="outdir",
> prefix="f.",suffix=".out">;
> file out[]<simple_mapper; location="outdir",
> foreach i in [0:1] {
> foreach j in [0:1]{
> file data<"data.txt">;
> out[j] = cat(data);
> It runs into the cache error after completing few tasks successfully:
> $ swift catsn.swift
> Swift trunk swift-r6410 cog-r3648
> RunID: 20130401-1745-7khkyrqc
> Progress: time: Mon, 01 Apr 2013 17:45:59 -0500
> Progress: time: Mon, 01 Apr 2013 17:46:00 -0500 Selecting site:1
> Active:1 Finished successfully:2
> Execution failed:
> Exception in cat:
> Arguments: [data.txt]
> Host: localhost
> Directory: catsn-20130401-1745-7khkyrqc/jobs/y/cat-yzf9fg7l
> Caused by:
> The cache already contains
> localhost:catsn-20130401-1745-7khkyrqc/shared/outdir/f.0000.out.
> cat, catsn.swift, line 14
> The cause, I think is that the nested loop triggers the same series
> of random sequences in mappers code which collides. Both, the simple
> and the concurrent mappers fail with same message.
> Does anyone know of a workaround?
> Thanks,
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
