[Swift-devel] foreach.max.threads question
Mihael Hategan
hategan at mcs.anl.gov
Tue Oct 16 18:41:18 CDT 2012
On Tue, 2012-10-16 at 16:19 -0500, David Kelly wrote:
> I set the max threads to 520 and saw the same behavior. The only
> difference is that I had to do the work on OSG rather than UC3 since
> all nodes were in use. Is it possible that since there is no foreach
> throttle, all the files and file arrays needed for each of the 120K
> tasks are getting set at once?
That's correct.
I guess that was a bit of wishful thinking on my side. I will revert the
change. In the mean-time, please use the revision before the change.
Mihael
