[Swift-devel] foreach.max.threads question
Mihael Hategan
hategan at mcs.anl.gov
Tue Oct 16 14:44:59 CDT 2012
The default is 16384. Can you set foreach.max.threads to 520 and try
again?
On Tue, 2012-10-16 at 14:25 -0500, David Kelly wrote:
> Swift and coaster-service are running on communicado/bridled and the work is being done on UC3 via persistent coasters. UC3 has 520 cores, 1 core per node. In most cases I will get all 520 cores.
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > To: "David Kelly" <davidk at ci.uchicago.edu>
> > Cc: "swift-devel Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Tuesday, October 16, 2012 2:17:06 PM
> > Subject: Re: [Swift-devel] foreach.max.threads question
> > How many cores do you run this on?
> > On Tue, 2012-10-16 at 13:56 -0500, David Kelly wrote:
> > > Previously it was not explicitly set, so I am assuming it would have
> > > been 1024. As a test I tried setting it to 520 (the maximum number
> > > of available cores), but that did not seem to help.
> > > > Sent: Tuesday, October 16, 2012 1:44:47 PM
> > > > What was foreach.max.threads set to before?
> > > > On Tue, 2012-10-16 at 11:04 -0500, David Kelly wrote:
> > > > > Hello,
> > > > > I have noticed that since the foreach.max.threads changes, the
> > > > > DSSAT
> > > > > script is now running out of memory. I have the heap size set to
> > > > > 4
> > > > > gigabytes. There are 120K items in gridLists.
> > > > > The main foreach loop of the script looks like this:
> > > > > foreach g,i in gridLists {
> > > > > file tar_output <single_file_mapper; file=@strcat("output/",
> > > > > gridLists[i], "output.tar.gz")>;
> > > > > file part_output <single_file_mapper; file=@strcat("parts/",
> > > > > gridLists[i], ".part")>;
> > > > > file in1[] <filesys_mapper;
> > > > > location=@strcat(@arg("scenarios"),
> > > > > "/", gridLists[i]), pattern="*">; // Scenario files
> > > > > file in2[] <filesys_mapper; location=@strcat(@arg("weather"),
> > > > > "/", gridLists[i]), pattern="*">; // Weather files
> > > > > file in3[] <filesys_mapper; location=@arg("refdata"),
> > > > > pattern="*">; // Common data
> > > > > file in4[] <filesys_mapper; location=@arg("bindata"),
> > > > > pattern="*.EXE">; // Binaries
> > > > > file in5[] <filesys_mapper; location=@arg("bindata"),
> > > > > pattern="*.pl">; // Perl scripts
> > > > > file wrapper <single_file_mapper; file="RunDSSAT.sh">; //
> > > > > RunDSSAT wrapper
> > > > > (tar_output, part_output) = RunDSSAT(xfile, in1, in2, in3,
> > > > > in4,
> > > > > in5, wrapper);
> > > > > Is there any way to throttle foreach again, or any other
> > > > > workarounds
> > > > > I could use to avoid this?
> > > > > Thanks,
> > > > > David
> > > > > _______________________________________________
> > > > > Swift-devel mailing list
> > > > > Swift-devel at ci.uchicago.edu
> > > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
