[Swift-devel] Changes to array closing semantics?
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Wed Nov 21 18:50:56 CST 2012
I had a couple of comments.
I think the difference between Swift/K and Swift/T is mostly implementation
rather than to do with restrictions on semantics - there weren't really any
decisions I made where I was restricting something in order to avoid
potential deadlocks.   (There might be some differences where we're
better/worse at detecting deadlocks at compile time, but that's a separate
issue).
I don't see why this example necessarily deadlocks - it doesn't in Swift/T
since there isn't a true data dependence loop.
foreach i in [0:10] {
  a[i] = 1;
  f(a);
In Swift/T it does the same thing as:
  a[i] = 1;
  f(a);
I understand in Swift/K there is some sort of dependence loop ( scope
exiting <- f(a) executing <- a being closed <- scope exiting).  In Swift/T
the statements a[i] = 1 and f(a) are forked off separately, then the
writers count is decremented after each insertion succeeds.  There isn't an
explicit runtime event corresponding to all statements in a block finishing.
- Tim
On Wed, Nov 21, 2012 at 3:51 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Wed, 2012-11-21 at 12:12 -0700, Justin M Wozniak wrote:
> > I don't think this is currently an issue in the Swift/T implementation
> > but I can check.  In Swift/T, we have the restriction that you cannot
> > assign to an array A=f() and also do piecemeal assignments A[i]=g() .
> > We do track potential write accesses to arrays to keep them open until
> > there are no more possible writes.
> > http://www.mcs.anl.gov/exm/local/guides/swift.html#_arrays
> That restriction should also be in swift/k, and I don't think it is.
> There is a problem with the current implementation. It fails to properly
> execute the following code:
> int[] a;
> if (true) {
>   if (true) {
>     a[0] = 1;
>   else {
>    a[0] = 2;
>   f(a);
> This is because a is closed in the scope in which it's declared, but
> that won't be done until f(a) completes, which it can't because a is not
> closed. That needs fixing. An additional complexity is that the
> following should also be allowed and function correctly:
> int[] a;
> if (true) {
>   if (condition) {
>     a[0] = 1;
>   f(a);
> There's also the issue of:
> int[] a;
>   a[i] = 1;
>   f(a);
> That shouldn't be allowed. It is, and it leads to a deadlock.
> There are some subtleties:
> int[] a;
> if (true) {
>     if (true) {
>       a[i] = 0;
>     else {
>       a[i] = 1;
>   f(a);
> Closing of a can only happen after the foreach is done.
> All these cases need to be correctly handled by the compiler, and I
> think none of them are.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20121121/75834964/attachment.html>
