[Swift-devel] Changes to array closing semantics?
Justin M Wozniak wozniak at mcs.anl.gov
Wed Nov 21 13:12:35 CST 2012
On 11/21/2012 10:47 AM, Michael Wilde wrote:
>> int[] a;
>> scope1 {
>> scope2 {
>> a[i1] = v1;
>> f(a);
>> scope3 {
>> a[i2] = v2;
>> and variations.
>> It's not trivial because I need to keep track of both read and write
>> access to variables, and also their respective locations within the
>> scope tree, as well as how iterations and if conditions may affect
>> things. That combined with the general crappiness of the exiting
>> compiler code. But with a bit of work, I think it's doable and it will
>> go miles towards reducing unexpected and perplexing behavior in
>> complex
>> scripts.
> This is something that we should carefully coordinate between Swift/K and Swift/T.
> I dont fully understand this issues and differences, but I think that Swift/T has added some restrictions that make array closing simpler to define and implement.
> I would like to see us either agree on carying the new semantics forward into Swift/T, or retrofitting Swift/T semantics to Swift/K, to start easing the eventual transition for users.
> Thoughts, all?
> - Mike
I don't think this is currently an issue in the Swift/T implementation
but I can check.  In Swift/T, we have the restriction that you cannot
assign to an array A=f() and also do piecemeal assignments A[i]=g() .
We do track potential write accesses to arrays to keep them open until
there are no more possible writes.
http://www.mcs.anl.gov/exm/local/guides/swift.html#_arrays
We are currently working on a feature to provide better reporting in
user error cases.  For example, if a user tries to read from A[3][2] but
that is never assigned the error output is not very clear but we are
working on that- we will have to look back to find the original phrasing
of the lookup.  (Swift/T sets tmp=A[3], looks up tmp[2], and fails-
currently we can only say that entry [2] of an anonymous array was not
found, which is not helpful enough.)
     Justin
Justin M Wozniak
