[Swift-devel] changes in trunk (tracing and usability)
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Nov 10 13:23:59 CST 2012
On Sat, 2012-11-10 at 07:34 -0600, Michael Wilde wrote:
> All sounds very cool - Im eager to try this. We may want to update 0.94 with these features, or push 0.94 out sooner and release this as 0.95.
I think it's 0.95 material because it needs testing. And I do think we
should release more often.
Mihael
> - Mike
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Friday, November 9, 2012 11:54:45 PM
> > Subject: [Swift-devel] changes in trunk (tracing and usability)
> > Hello,
> > I added a few things in trunk meant to make it easier to debug issues
> > with scripts.
> > The major one is tracing. It's disabled by default, but can be enabled
> > with -tracing.enabled on the command line (or with the tracing.enabled
> > property).
> > What it does is it traces app calls, compound calls, assignments, etc.
> > It does it with line numbers, threads, and run-time information where
> > available (such as the exact values of the k, v pair for an iteration,
> > the exact arguments to a function or app, etc.).
> > Not all things are traced yet, but I wanted to see if it's useful
> > before
> > putting too much effort into it.
> > The minor ones are:
> > - stack traces for errors. When swift fails, it prints a swift stack
> > trace instead of just the error message with no location information.
> > This is in non-lazy error mode, and lazy errors might need more work.
> > - the "invalid path" errors are gone. You now get "Array index <value>
> > not found for <array> of <size>" or "Invalid field name <name> for
> > <struct_variable> of type <type>". These types of errors should be
> > caught at compile-time, but there are still places where the static
> > system can be bypassed.
> > - there was a race condition in the creation of array elements of
> > struct
> > type which would sometimes produce the "Invalid path
> > <valid_struct_field> for <variable>". It's fixed now.
> > Mihael
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
