[Swift-devel] osg sites
    David Kelly
    davidk at ci.uchicago.edu
    Sun May 20 15:41:10 CDT 2012
I would recommend trying the GlideinWMS scripts rather than the GRAM scripts. run-gwms-workers should work as far as I know (you may need to chmod +x it). The setup I was using to test provider staging on OSG are at /scratch3/davidk/coaster-stress-tests on engage-submit3.
David
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Sunday, May 20, 2012 2:41:13 PM
> Subject: Re: [Swift-devel] osg sites
> I'm trying the swift-workers and related scripts in trunk. Are those
> supposed to work?
> For one, swift-workers has "input = worker.pl" which seems to indicate
> that worker.pl is sent to the condor job through stdin, but in
> run-worker.sh I see the "cat >worker.pl" line commented out.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
