[Swift-devel] Comparing Swift and Hadoop
Ketan Maheshwari ketancmaheshwari at gmail.com
Mon May 14 19:54:03 CDT 2012
Tim,
>From your description and my limited experience (~3 weeks) with Hadoop, I
want to say that the differences between Hadoop and Swift are really "soft"
ones. I have a feeling that since MapReduce happened to be used for
internet scale/style reliability, Hadoop developers developed tools that
you described (compression, checksum, serialization, etc.) around it.
I want to think that Swift is in a sense superset of Hadoop or Hadoop+ in
that it essentially provides the same or similar functionality as one would
expect out of Hadoop with an added advantage of having an ability to
express the computation as a chained stages.
I do not really think the argument of running either on reliable or
unreliable systems really holds, since, Swift could be easily adapted to
unreliable systems by building functionalities (eg. data replication)
around it.
In another sense, I want to think Hadoop and Swift as tools solving same
class of problems with a huge overlap between them among functionalities
and only the extra 'muscles' bit which makes them different.
>From a user's point of view, I still think Hadoop is difficult to setup and
work with on medium sized applications (tens to hundreds of tasks). In
terms of application performance, I want to think, it depends on how good a
job one does tuning Hadoop and/or Swift for the application and
infrastructure at hand. This particular  thing, I am in the process of
doing and soon will come up with some concrete numbers.
Ketan
On Mon, May 14, 2012 at 5:15 PM, Tim Armstrong <tim.g.armstrong at gmail.com>wrote:
> To be clear, I'm not making the case that it's *impossible* to implement
> things in Swift that are implemented in MapReduce, just that Swift isn't
> well suited to them, because it wasn't designed with them in mind.  I've
> seen the argument before that MapReduce is a particular data flow DAG, and
> that you can express arbitrary data flow DAGs in other systems, but I think
> that somewhat misses the point of what MapReduce is trying to provide to
> application developers.  By treating all tasks and data dependencies as
> equivalent, it ignores all of the runtime infrastructure that MapReduce
> inserts into the processes, and ignores, for example, some of the details
> of how data is moved between mappers and reducers.
> For example, a substantial amount of code in the Hadoop MapReduce code
> base has to do with a) file formats b) compression c) checksums d)
> serialization e) buffering input and output data and f) bucketing/sorting
> the data.  This is all difficult to implement well and important for many
> big data applications.  I think that scientific workflow systems don't take
> any of these things seriously since it isn't important for most canonical
> scientific workflow applications.
> I think one of the other big differences is that Hadoop assumes that all
> you have are a bunch of unreliable machines on a network, so that it must
> provide its own a job scheduler and replicated distributed file system.
> Swift, in contrast, seems mostly designed for systems where there is a
> reliable shared file system, and where it acquires compute resources for a
> fixed blocks of time from some existing cluster manager.  I know there are
> ways you can have Swift/Coaster/Falkon run on networks of unreliable
> machines, but it's not quite like Hadoop's job scheduler which is designed
> to actually be the primary submission mechanism for a multi-user cluster.
> I don't think it would make much sense to run Swift on a network of
> unreliable machines and then to just leave your data on those machines (you
> would normally stage the final data to some backed-up file system), but it
> would make perfect sense for Hadoop, especially if the data is so big that
> it's difficult to find someplace else to put it.  In contrast, you can
> certainly stand up a Hadoop instance on a shared cluster for a few hours to
> run your jobs, and stage data in and out of HDFS, but that use case isn't
> what Hadoop was designed or optimized for. Most of the core developers on
> Hadoop are working in environments where they have devoted Hadoop clusters,
> where they can't afford much cluster downtime and where they need to
> reliably persist huge amounts of data for years on unreliable hardware.
> E.g. at the extreme end, this is the kind of thing Hadoop developers are
> thinking about:
> https://www.facebook.com/notes/paul-yang/moving-an-elephant-large-scale-hadoop-data-migration-at-facebook/10150246275318920
> - Tim
> On Sun, May 13, 2012 at 3:57 PM, Ioan Raicu <iraicu at cs.iit.edu> wrote:
>> Hi Tim,
>> I always thought of MapReduce being a subset of workflow systems. Can you
>> give me an example of an application that can be implemented in MapReduce,
>> but not a workflow system such as Swift? I can't think of any off the top
>> of my head.
>> Ioan
>> Ioan Raicu, Ph.D.
>> Assistant Professor
>> Computer Science Department
>> Illinois Institute of Technology
>> 10 W. 31st Street Chicago, IL 60616
>> Cel:   1-847-722-0876
>> Email: iraicu at cs.iit.edu
>> Web:   http://www.cs.iit.edu/~iraicu/
>> On May 13, 2012, at 1:09 PM, Tim Armstrong <tim.g.armstrong at gmail.com>
>> wrote:
>> I've worked on both Swift and Hadoop implementations and my tendency is
>> to say that there isn't actually any deep similarity beyond them both
>> supporting  distributed data processing/computation.  They both make
>> fundamentally different assumptions about the clusters they run on and the
>> applications they're supporting.
>> Swift is mainly designed for time-shared clusters with reliable shared
>> file systems. Hadoop assumes that it will be running on unreliable
>> commodity machines with no shared file system, and will be running
>> continuously on all machines on the cluster.  Swift is designed for
>> orchestrating existing executables with their own file formats, so mostly
>> remains agnostic to the contents of the files it is processing.  Hadoop
>> needs to have some understanding of the contents of the files it is
>> processing, to be able to segment them into records and perform key
>> comparisons so it can do a distributed sort, etc.  It provides its own file
>> formats (including compression, serialization, etc) that users can use,
>> although is extensible to custom file formats.
>>    - Hadoop implements its own distributed file-system with software
>>    redundancy, Swift uses an existing cluster filesystem or node-local file
>>    systems.  For bulk data processing, this means Hadoop will generally be
>>    able to deliver more disk bandwidth and has a bunch of other implications.
>>    - Hadoop has a record-oriented view of the world, i.e. it is built
>>    around the idea that you are processing a record at at time, rather than a
>>    file at a time as in Swift
>>    - As a result, Hadoop includes a bunch of functionality to do with
>>    file formats, compression, serialization etc: Swift is B.Y.O. file format
>>    - Hadoop's distributed sort is a core part of the MapReduce (and
>>    something that a lot of effort has gone into implementing and optimizing),
>>    Swift doesn't have built-in support for anything similar
>>    - Swift lets you construct arbitrary dataflow graphs between tasks,
>>    so in some ways is less restrictive than the map-reduce pattern (although
>>    it doesn't directly support some things that the map-reduce pattern does,
>>    so I wouldn't say that it is strictly more general)
>> I'd say that some applications might fit in both paradigms, but that
>> neither supports a superset of the applications that the other supports.
>> Performance would depend to a large extent on the application.  Swift might
>> actually be quicker to start up a job and dispatch tasks (Hadoop is
>> notoriously slow on that front), but otherwise I'd say it just depends on
>> the application, how you implement the application, the cluster, etc. I'm
>> not sure that there is a fair comparison between the two systems since
>> they're just very different: most of the results would be predictable just
>> be looking at the design of the system (e.g. if the application needs to do
>> a big distributed sort, Hadoop is much better) .  If the application is
>> embarrassingly parallel (like it sounds like your application is), then you
>> could probably implement it in either, but I'm not sure that it would
>> actually stress the differences between the systems if data sizes are small
>> and runtime is mostly dominated by computation.
>> I think the Cloudera Hadoop distribution is well documented reasonably
>> easy to set up and run, provided that you're not on a time-shared cluster.
>> Apache Hadoop is more of a pain to get working.
>> - Tim
>> On Sun, May 13, 2012 at 9:27 AM, Ketan Maheshwari <
>> ketancmaheshwari at gmail.com> wrote:
>>> Hi,
>>> We are working on a project from GE Energy corporation which runs
>>> independent MonteCarlo simulations in order to find device reliability
>>> leading to a power grid wise device replacement decisions. The computation
>>> is repeated MC simulations done in parallel.
>>> Currently, this is running under Hadoop setup on Cornell Redcloud and
>>> EC2 (10 nodes). Looking at the computation, it struck me this is a good
>>> Swift candidate. And since the performance numbers etc are already
>>> extracted for Hadoop, it might also be nice to have a comparison between
>>> Swift and Hadoop.
>>> However, some reality check before diving in: has it been done before?
>>> Do we know how Swift fares against map-reduce? Are they even comparable? I
>>> have faced this question twice here: Why use Swift when you have Hadoop?
>>> I could see Hadoop needs quite a bit of setup effort before getting it
>>> to run. Could we quantify usability and compare the two?
>>> Any ideas and inputs are welcome.
>>> Regards,
>>> Ketan
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120514/0fc937fb/attachment.html>
