[Swift-devel] Comparing Swift and Hadoop
Tim Armstrong
tim.g.armstrong at gmail.com
Mon May 14 16:15:01 CDT 2012
To be clear, I'm not making the case that it's *impossible* to implement
things in Swift that are implemented in MapReduce, just that Swift isn't
well suited to them, because it wasn't designed with them in mind. I've
seen the argument before that MapReduce is a particular data flow DAG, and
that you can express arbitrary data flow DAGs in other systems, but I think
that somewhat misses the point of what MapReduce is trying to provide to
application developers. By treating all tasks and data dependencies as
equivalent, it ignores all of the runtime infrastructure that MapReduce
inserts into the processes, and ignores, for example, some of the details
of how data is moved between mappers and reducers.
For example, a substantial amount of code in the Hadoop MapReduce code base
has to do with a) file formats b) compression c) checksums d) serialization
e) buffering input and output data and f) bucketing/sorting the data. This
is all difficult to implement well and important for many big data
applications. I think that scientific workflow systems don't take any of
these things seriously since it isn't important for most canonical
scientific workflow applications.
I think one of the other big differences is that Hadoop assumes that all
you have are a bunch of unreliable machines on a network, so that it must
provide its own a job scheduler and replicated distributed file system.
Swift, in contrast, seems mostly designed for systems where there is a
reliable shared file system, and where it acquires compute resources for a
fixed blocks of time from some existing cluster manager. I know there are
ways you can have Swift/Coaster/Falkon run on networks of unreliable
machines, but it's not quite like Hadoop's job scheduler which is designed
to actually be the primary submission mechanism for a multi-user cluster.
I don't think it would make much sense to run Swift on a network of
unreliable machines and then to just leave your data on those machines (you
would normally stage the final data to some backed-up file system), but it
would make perfect sense for Hadoop, especially if the data is so big that
it's difficult to find someplace else to put it. In contrast, you can
certainly stand up a Hadoop instance on a shared cluster for a few hours to
run your jobs, and stage data in and out of HDFS, but that use case isn't
what Hadoop was designed or optimized for. Most of the core developers on
Hadoop are working in environments where they have devoted Hadoop clusters,
where they can't afford much cluster downtime and where they need to
reliably persist huge amounts of data for years on unreliable hardware.
E.g. at the extreme end, this is the kind of thing Hadoop developers are
thinking about:
https://www.facebook.com/notes/paul-yang/moving-an-elephant-large-scale-hadoop-data-migration-at-facebook/10150246275318920
- Tim
On Sun, May 13, 2012 at 3:57 PM, Ioan Raicu <iraicu at cs.iit.edu> wrote:
> Hi Tim,
> I always thought of MapReduce being a subset of workflow systems. Can you
> give me an example of an application that can be implemented in MapReduce,
> but not a workflow system such as Swift? I can't think of any off the top
> of my head.
> Ioan
> Ioan Raicu, Ph.D.
> Assistant Professor
> Computer Science Department
> Illinois Institute of Technology
> 10 W. 31st Street Chicago, IL 60616
> Cel: 1-847-722-0876
> Email: iraicu at cs.iit.edu
> Web: http://www.cs.iit.edu/~iraicu/
> On May 13, 2012, at 1:09 PM, Tim Armstrong <tim.g.armstrong at gmail.com>
> wrote:
> I've worked on both Swift and Hadoop implementations and my tendency is to
> say that there isn't actually any deep similarity beyond them both
> supporting distributed data processing/computation. They both make
> fundamentally different assumptions about the clusters they run on and the
> applications they're supporting.
> Swift is mainly designed for time-shared clusters with reliable shared
> file systems. Hadoop assumes that it will be running on unreliable
> commodity machines with no shared file system, and will be running
> continuously on all machines on the cluster. Swift is designed for
> orchestrating existing executables with their own file formats, so mostly
> remains agnostic to the contents of the files it is processing. Hadoop
> needs to have some understanding of the contents of the files it is
> processing, to be able to segment them into records and perform key
> comparisons so it can do a distributed sort, etc. It provides its own file
> formats (including compression, serialization, etc) that users can use,
> although is extensible to custom file formats.
> - Hadoop implements its own distributed file-system with software
> redundancy, Swift uses an existing cluster filesystem or node-local file
> systems. For bulk data processing, this means Hadoop will generally be
> able to deliver more disk bandwidth and has a bunch of other implications.
> - Hadoop has a record-oriented view of the world, i.e. it is built
> around the idea that you are processing a record at at time, rather than a
> file at a time as in Swift
> - As a result, Hadoop includes a bunch of functionality to do with
> file formats, compression, serialization etc: Swift is B.Y.O. file format
> - Hadoop's distributed sort is a core part of the MapReduce (and
> something that a lot of effort has gone into implementing and optimizing),
> Swift doesn't have built-in support for anything similar
> - Swift lets you construct arbitrary dataflow graphs between tasks, so
> in some ways is less restrictive than the map-reduce pattern (although it
> doesn't directly support some things that the map-reduce pattern does, so I
> wouldn't say that it is strictly more general)
> I'd say that some applications might fit in both paradigms, but that
> neither supports a superset of the applications that the other supports.
> Performance would depend to a large extent on the application. Swift might
> actually be quicker to start up a job and dispatch tasks (Hadoop is
> notoriously slow on that front), but otherwise I'd say it just depends on
> the application, how you implement the application, the cluster, etc. I'm
> not sure that there is a fair comparison between the two systems since
> they're just very different: most of the results would be predictable just
> be looking at the design of the system (e.g. if the application needs to do
> a big distributed sort, Hadoop is much better) . If the application is
> embarrassingly parallel (like it sounds like your application is), then you
> could probably implement it in either, but I'm not sure that it would
> actually stress the differences between the systems if data sizes are small
> and runtime is mostly dominated by computation.
> I think the Cloudera Hadoop distribution is well documented reasonably
> easy to set up and run, provided that you're not on a time-shared cluster.
> Apache Hadoop is more of a pain to get working.
> - Tim
> On Sun, May 13, 2012 at 9:27 AM, Ketan Maheshwari <
> ketancmaheshwari at gmail.com> wrote:
>> Hi,
>> We are working on a project from GE Energy corporation which runs
>> independent MonteCarlo simulations in order to find device reliability
>> leading to a power grid wise device replacement decisions. The computation
>> is repeated MC simulations done in parallel.
>> Currently, this is running under Hadoop setup on Cornell Redcloud and EC2
>> (10 nodes). Looking at the computation, it struck me this is a good Swift
>> candidate. And since the performance numbers etc are already extracted for
>> Hadoop, it might also be nice to have a comparison between Swift and Hadoop.
>> However, some reality check before diving in: has it been done before? Do
>> we know how Swift fares against map-reduce? Are they even comparable? I
>> have faced this question twice here: Why use Swift when you have Hadoop?
>> I could see Hadoop needs quite a bit of setup effort before getting it to
>> run. Could we quantify usability and compare the two?
>> Any ideas and inputs are welcome.
>> Regards,
>> Ketan
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120514/c51141e3/attachment.html>
