[Swift-devel] Beagle needs from Swift
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu May 10 14:53:47 CDT 2012
On May 10, 2012, at 14:49, David Kelly <davidk at ci.uchicago.edu> wrote:
>> David and Justin, can
>> you attend (with me and Lorenzo) to help users hands-on? Proposed time
>> is 2 hours; short talk and then hands-on.
> Sure, I'd be happy to help.
>> 2. Jon, Lorenzo i interested in a portable swiftrun command. Can you
>> check in your start on that, ideally with some asciidoc user guide
>> info?
> Yep, I'd like to start working on that again. We can probably start with with one of the shell scripts we have for DSSAT/PsiColSim/SWAT.
So that is the one have. It is based off of SciColSim. I used the same template to make the DSSAT run script and sleepn run script for the benchmarks. I will check in what I have and start on the Asciidoc.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
