[Swift-devel] Beagle needs from Swift
    Michael Wilde
    wilde at mcs.anl.gov
    Thu May 10 14:45:20 CDT 2012
> > 4. One Swift script Lorenzo is constructing may need to control
> > jobsPerNode on a per-app basis. Justin, I forgot: can your latest
> > mod for per-app attributes handle that?
> Not currently. That is not a simple per-job setting. To get that would
> take a more significant change to the Cpu allocation scheme. I would
> like to do that at some point.
So for now, Lorenzo, the way to do this is to use a separate site (sites.xml <pool> entry) for each different value of jobsPerNode that you require. I assume most will be 24, and only the large-memory apps will need a lower number (2,4,8 etc).
Then in the tc.data file, list those exception applications as being associated with only the right pool entry.
- Mike
