[Swift-devel] Coaster socket issue
David Kelly
davidk at ci.uchicago.edu
Wed Mar 28 21:11:31 CDT 2012
The limit here seems to be 1024.
Just curious, what happens when you run 'lsof -u jonmon'? For me, I see lines like this that grow over time:
java 14589 dkelly 220r FIFO 0,6 601514288 pipe
java 14589 dkelly 221r FIFO 0,6 601514581 pipe
java 14589 dkelly 222w FIFO 0,6 601514852 pipe
java 14589 dkelly 223r FIFO 0,6 601514582 pipe
----- Original Message -----
> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: "swift-devel at ci.uchicago.edu Devel" <swift-devel at ci.uchicago.edu>
> Sent: Wednesday, March 28, 2012 8:57:03 PM
> Subject: Re: [Swift-devel] Coaster socket issue
> What is the open files limit on that machine(ulimit -n)? I have never
> witnessed this issue before so it may only appear on machines with
> relatively low open file limits(raven has 1K but beagle has 60K). This
> is still something we should look into though.
> On Mar 28, 2012, at 8:49 PM, David Kelly wrote:
> > Strange, I just ran into a similar issues tonight while running on
> > ibicluster (SGE). I saw the "too many open files" error after
> > sitting in the queue waiting for a job to start. I restarted the job
> > and then periodically ran 'lsof' to see the number of java pipes
> > increasing over time. I thought at first this might be SGE specific,
> > but perhaps it is something else. (This was with 0.93)
> >> To: "swift-devel at ci.uchicago.edu Devel"
> >> Sent: Wednesday, March 28, 2012 8:30:52 PM
> >> Subject: [Swift-devel] Coaster socket issue
> >> Hello,
> >> In running the SciColSim app on raven(which is a cluster similar to
> >> Beagle) I noticed that the app hung. It was not hung where the hang
> >> checker kicked in but Swift was waiting for jobs to be active but
> >> there was none submitted to PBS. I took a look at the log file and
> >> noticed that I had a java.io.IOException thrown for "too many open
> >> files". Since I killed it I couldn't probe the run but I had the
> >> same
> >> run running on Beagle. Upon Mike's suggestion I took a look at the
> >> /proc/<pid>/fd directory. There were over 2000 sockets in the
> >> CLOSE_WAIT state with a single message in the receive queue. Raven
> >> has
> >> a limit of 1024 open files at a time while Beagle has a limit
> >> around
> >> 60K number of files open. I got this limit using ulimit -n.
> >> So my question is, why is there so many sockets waiting to be
> >> closed?
> >> I did some reading about the CLOSE_WAIT state and it seems this
> >> happens when one of the ends closes there socket but the other does
> >> not. Is Coaster not closing the socket when a worker shuts down?
> >> What
> >> other information should I be looking for to help debug the issue.
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
