[Swift-devel] Montage+Swift workflow fails on Surveyor
Emalayan Vairavanathan svemalayan at yahoo.com
Fri Mar 23 05:02:42 CDT 2012
Hi Jon,
I tired to run Montage-Swift setup on surveyor withpersistent coasters and GPFS (this is without cdm). The last stage of the workflow fails. Have you ever tried this before on Surveyor? Do you have any clues about this issue?
It would be great if you can have a look ? (I pasted the standard out put below).
The setup is available in /home/emalayan/app/montage-swift/SwiftMontage/scripts.
After starting the coasters via start-coaster-service, please use ./run_pc.sh to run the setup. Please let me know if I can help you in anyways.
Thank you
Emalayan
 ========================================stdout==============================================
emalayan at login2.surveyor:~/app/montage-swift/SwiftMontage/scripts> ./run_pc.sh
Swift trunk swift-r5704 (swift modified locally) cog-r3361 (cog modified locally)
RunID: 20120323-0900-oidnkire
 (input): found 10 files
Progress:  time: Fri, 23 Mar 2012 09:00:40 +0000
Find: http://172.17.3.12:12346
Find:  keepalive(120), reconnect - http://172.17.3.12:12346
Progress:  time: Fri, 23 Mar 2012 09:00:54 +0000  Selecting site:4  Submitted:3  Active:2  Checking status:1
Progress:  time: Fri, 23 Mar 2012 09:01:07 +0000  Selecting site:1  Submitted:3  Active:2  Checking status:1  Finished successfully:3
Progress:  time: Fri, 23 Mar 2012 09:01:10 +0000  Submitted:1  Active:3  Finished successfully:6
Progress:  time: Fri, 23 Mar 2012 09:01:19 +0000  Submitted:1  Active:2  Checking status:1  Finished successfully:6
Progress:  time: Fri, 23 Mar 2012 09:01:32 +0000  Checking status:1  Finished successfully:9
Progress:  time: Fri, 23 Mar 2012 09:01:34 +0000  Checking status:1  Finished successfully:10
Progress:  time: Fri, 23 Mar 2012 09:01:35 +0000  Checking status:1  Finished successfully:11
Progress:  time: Fri, 23 Mar 2012 09:01:36 +0000  Selecting site:12  Submitted:3  Active:2  Checking status:1  Finished successfully:12
Progress:  time: Fri, 23 Mar 2012 09:01:38 +0000  Selecting site:9  Submitted:3  Active:2  Checking status:1  Finished successfully:15
Progress:  time: Fri, 23 Mar 2012 09:01:39 +0000  Selecting site:6  Submitted:3  Active:2  Checking status:1  Finished successfully:18
Progress:  time: Fri, 23 Mar 2012 09:01:40 +0000  Selecting site:3  Submitted:3  Active:3  Finished successfully:21
Progress:  time: Fri, 23 Mar 2012 09:01:41 +0000  Submitted:3  Active:3  Finished successfully:24
Progress:  time: Fri, 23 Mar 2012 09:01:43 +0000  Active:2  Checking status:1  Finished successfully:27
Progress:  time: Fri, 23 Mar 2012 09:01:44 +0000  Checking status:1  Finished successfully:30
Progress:  time: Fri, 23 Mar 2012 09:01:46 +0000  Checking status:1  Finished successfully:31
Progress:  time: Fri, 23 Mar 2012 09:01:47 +0000  Checking status:1  Finished successfully:32
Progress:  time: Fri, 23 Mar 2012 09:01:49 +0000  Selecting site:4  Submitted:3  Active:2  Checking status:1  Finished successfully:33
Progress:  time: Fri, 23 Mar 2012 09:01:50 +0000  Selecting site:1  Submitted:3  Active:2  Checking status:1  Finished successfully:36
Progress:  time: Fri, 23 Mar 2012 09:01:52 +0000  Submitted:1  Active:2  Checking status:1  Finished successfully:39
Progress:  time: Fri, 23 Mar 2012 09:01:53 +0000  Finished successfully:42 Failed but can retry:1
EXCEPTION Exception in mBackground_wrap:
Arguments: [-n, proj_dir/proj_2mass-atlas-990214n-j1110032.fits, rect_dir/proj_2mass-atlas-990214n-j1110032.fits, 0.0, 0.0, 0.0]
Host: persistent-coasters
Directory: SwiftMontage-20120323-0900-oidnkire/jobs/t/mBackground_wrap-t3it8uok
stderr.txt:
stdout.txt: [struct stat="ERROR", status=252, msg="1st key not SIMPLE or XTENSION"]
Caused by: Application /home/emalayan/app/montage-swift/SwiftMontage/apps/mBackground_wrap.py failed with an exit code of 1
Execution failed:
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120323/4312fabe/attachment.html>
