[Swift-devel] using a reservation
Jonathan Monette
jonmon at mcs.anl.gov
Thu Mar 22 08:38:11 CDT 2012
Using pbs.resource_list in the in the providerAttributes key works. The google site that I was using does not specify this. It seems to lead you to using
<profile namespace="globes" key="pbs.resource_list">advres=res_id</profile> instead.
On Mar 22, 2012, at 8:03 AM, Michael Wilde wrote:
> Thanks, Ketan.
> We should match this against the 0.93 & trunk provider codes:
> pbs.aprun;pbs.mpp;pbs.resource_list=advres=modFTDock.47
> I was wondering if in fact pbs.properties needed to be specified in the manner you show here (above). Im wondering if pbs.resource_list was changed in a revision after you ran this?
> - Mike
>> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
>> To: "Jonathan Monette" <jonmon at mcs.anl.gov>
>> Cc: "swift-devel at ci.uchicago.edu Devel" <swift-devel at ci.uchicago.edu>
>> Sent: Thursday, March 22, 2012 7:56:38 AM
>> Subject: Re: [Swift-devel] using a reservation
>> Jon,
>> Here is a sites.xml that I used for a Beagle reservation a while ago
>> for modftdock. This worked well on swift-r4252 cog-r3088. See if it
>> helps at all comparing yours and this one:
>> <config>
>> <pool handle="pbs">
>> <execution provider="coaster" jobmanager="local:pbs"/>
>> <profile namespace="globus" key="project">CI-CCR000013</profile>
>> <profile namespace="globus" key="jobsPerNode">24</profile>
>> <profile namespace="globus" key="ppn">24</profile>
>> <profile namespace="globus" key="maxTime">16000</profile>
>> <profile namespace="globus" key="lowOverallocation">100</profile>
>> <profile namespace="globus" key="highOverallocation">100</profile>
>> <profile namespace="globus" key="providerAttributes">
>> </profile>
>> <profile namespace="globus" key="slots">25</profile>
>> <profile namespace="globus" key="nodeGranularity">2</profile>
>> <profile namespace="globus" key="maxNodes">2</profile>
>> <profile namespace="karajan" key="jobThrottle">13.00</profile>
>> <profile namespace="karajan" key="initialScore">10000</profile>
>> <filesystem provider="local"/>
>> <workdirectory>/lustre/beagle/ketan/labs/modftdock/bgl.reserved.run/swift.workdir</workdirectory>
>> </pool>
>> </config>
>> On Thu, Mar 22, 2012 at 12:37 AM, Jonathan Monette <
>> jonmon at mcs.anl.gov > wrote:
>> So I have been looking at this. I tried adding my own reservation key
>> to PBSExecutor but that does not seem to work. So my question is, does
>> this not work because the JobSpecification object does not know to
>> look for this attribute? If so, could this be the reason why I cannot
>> seem to get the reservation to the PBS script using pbs.properties or
>> pbs.resources(I also tried pbs.resource_list as that is what the code
>> looks for). Where does the JobSpecification get built? Where is the
>> xml sites file parsed? I cannot seem to find this code.
>> On Mar 21, 2012, at 10:57 PM, Justin M Wozniak wrote:
>>> I'll take a look at this tomorrow.
>>> On Wed, 21 Mar 2012, Michael Wilde wrote:
>>>> Jon,
>>>> Regarding the walltime, your sites file mis-spells maxwalltime;
>>>> hence the jobs emitted by your script probably dont sum to anything
>>>> beyond 17:00h at the 10m default time.
>>>> I dont see why the res isnt making it through to the PBS script.
>>>> - Mike
>>>>> From: "Jonathan Monette" < jonmon at mcs.anl.gov >
>>>>> To: " swift-devel at ci.uchicago.edu Devel" <
>>>>> swift-devel at ci.uchicago.edu >
>>>>> Sent: Wednesday, March 21, 2012 6:30:14 PM
>>>>> Subject: [Swift-devel] using a reservation
>>>>> Hello,
>>>>> I am trying to use a reservation I have on Beagle. Here is my
>>>>> sites
>>>>> file:
>>>>> <config>
>>>>> <pool handle="local" >
>>>>> <execution provider="local" url="none" />
>>>>> <profile namespace="karajan" key="jobThrottle">0.5</profile>
>>>>> <workdirectory>_WORK_/local</workdirectory>
>>>>> </pool>
>>>>> <pool handle="beagleRes">
>>>>> <profile namespace="env" key="SWIFT_GEN_SCRIPTS">KEEP</profile>
>>>>> <profile namespace="globus" key="project">CI-MCB000119</profile>
>>>>> <profile namespace="globus" key="jobsPerNode">1</profile>
>>>>> key="workerLoggingLevel">DEBUG</profile>
>>>>> key="workerLoggingDirectory">_WORK_/beagleRes/workers</profile>
>>>>> <profile namespace="globus" key="lowOverAllocation">100</profile>
>>>>> <profile namespace="globus" key="highOverAllocation">100</profile>
>>>>> key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
>>>>> <profile namespace="globus" key="maxTime">86400</profile>
>>>>> <profile namespace="globus" key="waxWallTime">00:04:00</profile>
>>>>> <profile namespace="globus" key="slots">1</profile>
>>>>> <profile namespace="globus" key="nodeGranularity">20</profile>
>>>>> <profile namespace="globus" key="maxNodes">20</profile>
>>>>> key="pbs.properties">advres=18833.687</profile>
>>>>> <profile namespace="karajan" key="jobThrottle">12.00</profile>
>>>>> <workdirectory>_WORK_/beagleRes</workdirectory>
>>>>> </pool>
>>>>> </config>
>>>>> I have tried both pbs.properties and pbs.resources as a sites
>>>>> entry, I
>>>>> got this information from
>>>>> https://sites.google.com/site/swiftdevel/sites/pbs
>>>>> However here is the pbs script that has been generated:
>>>>> #CoG This script generated by CoG
>>>>> #CoG by class: class
>>>>> org.globus.cog.abstraction.impl.scheduler.pbs.PBSExecutor
>>>>> #CoG on date: 2012/03/21 23:22:35
>>>>> #PBS -S /bin/bash
>>>>> #PBS -N Block-0321-2211
>>>>> #PBS -m n
>>>>> #PBS -A CI-MCB000119
>>>>> #PBS -l mppwidth=20,mppnppn=1,mppdepth=24
>>>>> #PBS -l walltime=17:00:00
>>>>> #PBS -o
>>>>> /home/jonmon/.globus/scripts/PBS1332885235909759395.submit.stdout
>>>>> #PBS -e
>>>>> /home/jonmon/.globus/scripts/PBS1332885235909759395.submit.stderr
>>>>> WORKER_LOGGING_LEVEL=DEBUG
>>>>> #PBS -v WORKER_LOGGING_LEVEL
>>>>> cd / && aprun -n 20 -N 1 -cc none -d 24 -F exclusive /bin/sh -c
>>>>> '/usr/bin/perl
>>>>> /home/jonmon/.globus/coasters/ cscript9177561070598799820.pl
>>>>> http://10.128.2.243:40904 , http://127.0.0.2:40904 ,
>>>>> http://192.5.86.103:40904
>>>>> 0321-221135-000000
>>>>> /lustre/beagle/jonmon/Swift/SciColSim/run163/swiftwork/beagleRes/workers'
>>>>> /bin/echo $?
>>>>>> /home/jonmon/.globus/scripts/PBS1332885235909759395.submit.exitcode
>>>>> I have asked for a coaster block of 24 hours(my reservation is 96
>>>>> hours) but it shows a wall time of 17 hours. Furthermore, the line
>>>>> #PBS -l advres=<res_id> is missing so I am not using my
>>>>> reservation, I
>>>>> just get added to the batch queue and sit there. Does any remember
>>>>> how
>>>>> to specify a reservation in the sites file for PBS?
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>> Justin M Wozniak
>> Ketan
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
