[Swift-devel] Mosaswift update
    Emalayan Vairavanathan
    svemalayan at yahoo.com
    Thu Mar 15 03:30:17 CDT 2012
Hi Jon and All,
MosaStore+Swift integration is done successfully. This is really a great news.
I successfully ran the setup provided by Jon with MosaStore+Swift on Surveyor (on 1, 3 , 5 and 64 nodes with different number of  jobs varying from 1 to 1024).
Jon and Mike thank you again for your time in helping me to get this far.
A quick question: The setup creates the swift working directory in GPFS but stores the intermediate files in MosaStore. Where should we actually have the swift-working directory (in GPFS / Mosa)? and Does this matter at all in case if I am going to use Mosa as an intermediate storage?
(As a next step I will be scripting our pipeline benchmark on swift and run at large scale to get some initial performance numbers. Also I will be parallely working to get Montage and ModFTDock running on BG/P with swift-CDM and MosaStore.)
Regards
Emalayan
To: Emalayan Vairavanathan <svemalayan at yahoo.com>
Cc: "mosastore at googlegroups.com" <mosastore at googlegroups.com>; Justin M Wozniak <wozniak at mcs.anl.gov>; "swift-devel at ci.uchicago.edu Devel" <swift-devel at ci.uchicago.edu>
Sent: Wednesday, 14 March 2012 2:29 PM
Subject: Re: [Swift-devel] Mosaswift update
The working example is located in /home/jonmon/Workspace/Swift/mosaswift-test
There is a README there that provides a little bit of information.
Quick version to run it:
1) start your workers
2) ./setup.sh
3) ./run.sh
The directory final will have 5 files if it completed without error.  The content of the files will look like:
Hello world
Hello from <number>
On Mar 14, 2012, at 4:03 PM, Emalayan Vairavanathan wrote:
Hi Jon,
>Great, Thank you very much. Could you please send me the setup ?
>Thank you
>Emalayan
>________________________________
> From: Jonathan Monette <jonmon at mcs.anl.gov>
>To: Justin M Wozniak <wozniak at mcs.anl.gov>
>Cc: "swift-devel at ci.uchicago.edu Devel" <swift-devel at ci.uchicago.edu>; MosaStore <mosastore at googlegroups.com>
>Sent: Wednesday, 14 March 2012 2:00 PM
>So that actually fixed the issue.  So we have a working example of using CDM and intermediate file storage that Emalayan can use for testing his mosa store set up.
>On Mar 14, 2012, at 3:05 PM, Jonathan Monette wrote:
>> Oh, thanks, didn't catch that.  Trying another run right now but I think someone is using all of surveyor right now, but manual coaster service job is stuck in the queue state.
>> On Mar 14, 2012, at 3:02 PM, Justin M Wozniak wrote:
>>> Ok, then it's a typo on readlinE .
>>> On Wed, 14 Mar 2012, Jonathan Monette wrote:
>>>> I am not sure.  I thought readlink returned the
 absolute path of the link which is what I wanted to use.  I am not sure how readlink behaves on the compute nodes.  This was my first attempt at getting around the link but I do not think this is working.
>>>>>> I say semi working because I intended the script to build up output during the stages on the swift run and the final output would show that it was stored temporarily in /tmp.  This is not happening as the final output for the file contains only the last line(a Hello from <id> line). I believe this is due to how CDM using symlinks for the files that is matched, so a symlink is being overwritten instead of at the file it points to.  I ran into this problem in the past(but this is documented in the user guide) and just
 need verify that this is indeed the issue.
>>>>> In the past, the application unlinked the link.  It looks like you are appending to the link.
>>>>> infile=`readlink $1`
>>>>> outfile=`readline $2`
>>>>> cat $infile >> $outfile
>>>>> Is there a case in which the readlink affects the behavior of this sequence?
>>>>> Does readline work correctly on the BG/P compute node?
>>>>>     Justin
>>>>> Justin M Wozniak
>>> Justin M Wozniak
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>You received this message because you are subscribed to the Google Groups "MosaStore" group.
>To post to this group, send email to mosastore at googlegroups.com.
>To unsubscribe from this group, send email to mosastore+unsubscribe at googlegroups.com.
>For more options, visit this group at http://groups.google.com/group/mosastore?hl=en.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120315/52ab843f/attachment.html>
