[Swift-devel] Mosaswift update
    Emalayan Vairavanathan
    svemalayan at yahoo.com
    Wed Mar 14 16:03:05 CDT 2012
Hi Jon,
Great, Thank you very much. Could you please send me the setup ?
Thank you
Emalayan
To: Justin M Wozniak <wozniak at mcs.anl.gov>
Cc: "swift-devel at ci.uchicago.edu Devel" <swift-devel at ci.uchicago.edu>; MosaStore <mosastore at googlegroups.com>
Sent: Wednesday, 14 March 2012 2:00 PM
Subject: Re: [Swift-devel] Mosaswift update
So that actually fixed the issue.  So we have a working example of using CDM and intermediate file storage that Emalayan can use for testing his mosa store set up.
On Mar 14, 2012, at 3:05 PM, Jonathan Monette wrote:
> Oh, thanks, didn't catch that.  Trying another run right now but I think someone is using all of surveyor right now, but manual coaster service job is stuck in the queue state.
> On Mar 14, 2012, at 3:02 PM, Justin M Wozniak wrote:
>> Ok, then it's a typo on readlinE .
>> On Wed, 14 Mar 2012, Jonathan Monette wrote:
>>> I am not sure.  I thought readlink returned the absolute path of the link which is what I wanted to use.  I am not sure how readlink behaves on the compute nodes.  This was my first attempt at getting around the link but I do not think this is working.
>>>>> I say semi working because I intended the script to build up output during the stages on the swift run and the final output would show that it was stored temporarily in /tmp.  This is not happening as the final output for the file contains only the last line(a Hello from <id> line). I believe this is due to how CDM using symlinks for the files that is matched, so a symlink is being overwritten instead of at the file it points to.  I ran into this problem in the past(but this is documented in the user guide) and just need verify that this is indeed the issue.
>>>> In the past, the application unlinked the link.  It looks like you are appending to the link.
>>>> infile=`readlink $1`
>>>> outfile=`readline $2`
>>>> cat $infile >> $outfile
>>>> Is there a case in which the readlink affects the behavior of this sequence?
>>>> Does readline work correctly on the BG/P compute node?
>>>>     Justin
>>>> Justin M Wozniak
>> Justin M Wozniak
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
You received this message because you are subscribed to the Google Groups "MosaStore" group.
To post to this group, send email to mosastore at googlegroups.com.
To unsubscribe from this group, send email to mosastore+unsubscribe at googlegroups.com.
For more options, visit this group at http://groups.google.com/group/mosastore?hl=en.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120314/f73a9e9a/attachment.html>
