[Swift-devel] sites.xml for ranger sge coasters
Michael Wilde
wilde at mcs.anl.gov
Thu Mar 8 11:07:57 CST 2012
> ...When SGE is used with coasters, the
> submit script should attempt to start 1 worker.pl on each node. A
> single worker.pl can handle multiple jobs. Instead, it was starting
> one worker.pl for every core on every node. If you set jobspernode to
> 16 and had 16 cores per node, you could see up to 256 jobs per node.
> I think this only affected SGE+Coasters, but we should add some tests
> to the suite to verify.
Code inspection of each local provider type might also help to verify that the generated submit files are all correct now.
- Mike
