[Swift-devel] [ZeptoOS] hostname returns none in Surveyor
ZHAO ZHANG
zhaozhang at uchicago.edu
Sun Mar 4 13:17:18 CST 2012
Yes, each compute node needs to run this script to bring up the network
interface.
zhao
On 3/4/2012 12:53 PM, Michael Wilde wrote:
> Thanks, Zhao. Does this need to run on each node at startup?
> If so should this logic be integrated into the worker startup script, Jon, Justin, Emalayan?
> Ive not looked at the current scripts much; I would think that all the BG/P specific logic of enabling the torus network and finding each node's IP address on the torus should be done in the init script rather than in the worker.
> - Mike
>> From: "ZHAO ZHANG"<zhaozhang at uchicago.edu>
>> To: "Michael Wilde"<wilde at mcs.anl.gov>
>> Cc: "Emalayan Vairavanathan"<svemalayan at yahoo.com>, swift-devel at ci.uchicago.edu
>> Sent: Sunday, March 4, 2012 12:18:28 PM
>> Subject: Re: [Swift-devel] [ZeptoOS] hostname returns none in Surveyor
>> Hi, Mike
>> With 192.168.1.*, we could only access the tree network. In order to
>> use
>> the torus network, we need to use the 12.x.y.z+1 ip address. (x, y, z
>> here is the coordinates of the compute nodes).
>> The code below could bring the torus ip address up.
>> IP=""
>> set_torus_ip()
>> x=$1
>> y=$2
>> z=$3
>> z=`expr $3 + 1`
>> ifconfig eth1 12.$x.$y.$z netmask 255.0.0.0 mtu 8996 -arp
>> IP=12.$x.$y.$z
>> BG_PSETORG=`cat /proc/personality.sh | grep BG_PSETORG | cut -d '"' -f
>> 2`
>> echo ${BG_PSETORG}>> /dev/shm/localip
>> set_torus_ip $BG_PSETORG
>> best
>> zhao
>> On 3/4/2012 10:24 AM, Michael Wilde wrote:
>>> Zhao,
>>> Can you tell us if the nodes on the torus network are accessed over
>>> the 192.168 network? I just realized they cant all be on the
>>> 192.168.1 subnet, so I hope I suggested the right network here.
>>> Thanks,
>>> - Mike
>>>> From: "Emalayan Vairavanathan"<svemalayan at yahoo.com>
>>>> To: swift-devel at ci.uchicago.edu
>>>> Sent: Sunday, March 4, 2012 1:40:53 AM
>>>> Surveyor
>>>> Thank you very much Mike. I agree with you suggestion. I can do
>>>> that
>>>> in worker.pl.
>>>> Thank you
>>>> Emalayan
>>>> From: Michael Wilde<wilde at mcs.anl.gov>
>>>> To: emalayan at ece.ubc.ca
>>>> Cc: swift-devel<swift-devel at ci.uchicago.edu>
>>>> Sent: Saturday, 3 March 2012 7:39 PM
>>>> Surveyor
>>>> Emalayan,
>>>> I wasnt paying much attention to the actual IP address returned by
>>>> hostname in the zeptoos profile.
>>>> Since these are the addresses that Mosa will communicate over, I
>>>> think
>>>> you *do* want them to be the 192.168.1.* addresses of the nodes on
>>>> the
>>>> torus network (in other words tun0).
>>>> So, since both profiles return 192.168.1.64 for the tun0 IP, I
>>>> think
>>>> thats what you should use. So try replacing `hostname` in worker.pl
>>>> with something like:
>>>> `ifconfig | grep 192.168 | sed -e 's/^inet addr://' -e 's/ .*//'`
>>>> You may have to adapt this a bit to meet your needs. Im assuming
>>>> that
>>>> the only code that will uses these IPs is MosaStore.
>>>> - Mike
>>>>> From: "Kazutomo Yoshii"< kazutomo at mcs.anl.gov>
>>>>> To: zeptoos at lists.mcs.anl.gov
>>>>> Sent: Saturday, March 3, 2012 8:52:00 PM
>>>>> Subject: Re: [ZeptoOS] hostname returns none in Surveyor
>>>>> Hi Emalayan,
>>>>> The zeptoos profile returns the IP address of associated I/O node,
>>>>> which is kind of wrong in my opinion (influence of IBM CNK).
>>>>> ifconfig on compute nodes returns CN's IP address, which is
>>>>> correct.
>>>>> e.g. tun0 192.168.1.64
>>>>> If you want to find associated ION's IP address from CNs,
>>>>> do something like this.
>>>>> $ grep BG_IP= /proc/personality.sh
>>>>> - kaz
>>>>> On 03/03/2012 08:25 PM, Emalayan Vairavanathan wrote:
>>>>>> Hi All,
>>>>>> I am trying to run some experiments in Surveyor. The software I
>>>>>> am
>>>>>> using
>>>>>> gets the IP-address of compute-nodes using hostname command.
>>>>>> With zepto-vn-eval/mosatest profile hostname command returns
>>>>>> none.
>>>>>> But with zeptoos profile hostname returns the correct IP address.
>>>>>> Is this due to some configuration issues in
>>>>>> profile?As a workaround I tired to use ifconfig with both
>>>>>> profiles,
>>>>>> but
>>>>>> it seems ifconfig is not returning the correct IP address.
>>>>>> Is there any command / files which I can used to retrieve the
>>>>>> hostname
>>>>>> on compute nodes? I have pasted the console output with both
>>>>>> profiles
>>>>>> below. Please let me know if you need more details.
>>>>>> Thank you
>>>>>> Emalayan
>>>>>> =======================With zeptoos profile
>>>>>> / # hostname
>>>>>> 172.18.3.19
>>>>>> / # cat /proc/sys/kernel/hostname
>>>>>> 172.18.3.19
>>>>>> / # ifconfig -a
>>>>>> lo Link encap:Local Loopback
>>>>>> inet addr:127.0.0.1 Mask:255.0.0.0
>>>>>> UP LOOPBACK RUNNING MTU:16436 Metric:1
>>>>>> RX packets:0 errors:0 dropped:0 overruns:0 frame:0
>>>>>> TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
>>>>>> collisions:0 txqueuelen:0
>>>>>> RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
>>>>>> tun0 Link encap:UNSPEC HWaddr
>>>>>> 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
>>>>>> inet addr:192.168.1.64 P-t-P:192.168.1.254 Mask:255.255.255.255
>>>>>> UP POINTOPOINT RUNNING NOARP MULTICAST MTU:65535 Metric:1
>>>>>> RX packets:2662 errors:0 dropped:0 overruns:0 frame:0
>>>>>> TX packets:1772 errors:0 dropped:0 overruns:0 carrier:0
>>>>>> collisions:0 txqueuelen:500
>>>>>> RX bytes:140206 (136.9 KiB) TX bytes:125412 (122.4 KiB)
>>>>>> =======================With zepto-vn-eval/mosatest profile
>>>>>> /etc # hostname
>>>>>> (none)
>>>>>> /etc #
>>>>>> /etc # cat /proc/sys/kernel/hostname
>>>>>> (none)
>>>>>> /etc #
>>>>>> /etc # ifconfig -a
>>>>>> eth0 Link encap:Ethernet HWaddr 00:80:46:00:00:00
>>>>>> BROADCAST MULTICAST MTU:1500 Metric:1
>>>>>> collisions:0 txqueuelen:1000
>>>>>> eth1 Link encap:Ethernet HWaddr 00:80:47:00:00:00
>>>>>> inet6 addr: ::1/128 Scope:Host
>>>>>> sit0 Link encap:IPv6-in-IPv4
>>>>>> NOARP MTU:1480 Metric:1
>>>>>> RX packets:965 errors:0 dropped:0 overruns:0 frame:0
>>>>>> TX packets:627 errors:0 dropped:0 overruns:0 carrier:0
>>>>>> RX bytes:50984 (49.7 KiB) TX bytes:50530 (49.3 KiB)
>>>> Michael Wilde
>>>> Computation Institute, University of Chicago
>>>> Mathematics and Computer Science Division
>>>> Argonne National Laboratory
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
