[Swift-devel] [ZeptoOS] hostname returns none in Surveyor
ZHAO ZHANG
zhaozhang at uchicago.edu
Sun Mar 4 12:18:28 CST 2012
Hi, Mike
With 192.168.1.*, we could only access the tree network. In order to use
the torus network, we need to use the 12.x.y.z+1 ip address. (x, y, z
here is the coordinates of the compute nodes).
The code below could bring the torus ip address up.
IP=""
set_torus_ip()
x=$1
y=$2
z=$3
z=`expr $3 + 1`
ifconfig eth1 12.$x.$y.$z netmask 255.0.0.0 mtu 8996 -arp
IP=12.$x.$y.$z
BG_PSETORG=`cat /proc/personality.sh | grep BG_PSETORG | cut -d '"' -f 2`
echo ${BG_PSETORG} >> /dev/shm/localip
set_torus_ip $BG_PSETORG
best
zhao
On 3/4/2012 10:24 AM, Michael Wilde wrote:
> Zhao,
> Can you tell us if the nodes on the torus network are accessed over the 192.168 network? I just realized they cant all be on the 192.168.1 subnet, so I hope I suggested the right network here.
> Thanks,
> - Mike
>> From: "Emalayan Vairavanathan"<svemalayan at yahoo.com>
>> To: swift-devel at ci.uchicago.edu
>> Sent: Sunday, March 4, 2012 1:40:53 AM
>> Subject: Re: [Swift-devel] [ZeptoOS] hostname returns none in Surveyor
>> Thank you very much Mike. I agree with you suggestion. I can do that
>> in worker.pl.
>> Thank you
>> Emalayan
>> From: Michael Wilde<wilde at mcs.anl.gov>
>> To: emalayan at ece.ubc.ca
>> Cc: swift-devel<swift-devel at ci.uchicago.edu>
>> Sent: Saturday, 3 March 2012 7:39 PM
>> Emalayan,
>> I wasnt paying much attention to the actual IP address returned by
>> hostname in the zeptoos profile.
>> Since these are the addresses that Mosa will communicate over, I think
>> you *do* want them to be the 192.168.1.* addresses of the nodes on the
>> torus network (in other words tun0).
>> So, since both profiles return 192.168.1.64 for the tun0 IP, I think
>> thats what you should use. So try replacing `hostname` in worker.pl
>> with something like:
>> `ifconfig | grep 192.168 | sed -e 's/^inet addr://' -e 's/ .*//'`
>> You may have to adapt this a bit to meet your needs. Im assuming that
>> the only code that will uses these IPs is MosaStore.
>> - Mike
>>> From: "Kazutomo Yoshii"< kazutomo at mcs.anl.gov>
>>> To: zeptoos at lists.mcs.anl.gov
>>> Sent: Saturday, March 3, 2012 8:52:00 PM
>>> Subject: Re: [ZeptoOS] hostname returns none in Surveyor
>>> Hi Emalayan,
>>> The zeptoos profile returns the IP address of associated I/O node,
>>> which is kind of wrong in my opinion (influence of IBM CNK).
>>> ifconfig on compute nodes returns CN's IP address, which is correct.
>>> e.g. tun0 192.168.1.64
>>> If you want to find associated ION's IP address from CNs,
>>> do something like this.
>>> $ grep BG_IP= /proc/personality.sh
>>> - kaz
>>> On 03/03/2012 08:25 PM, Emalayan Vairavanathan wrote:
>>>> Hi All,
>>>> I am trying to run some experiments in Surveyor. The software I am
>>>> using
>>>> gets the IP-address of compute-nodes using hostname command.
>>>> With zepto-vn-eval/mosatest profile hostname command returns none.
>>>> But with zeptoos profile hostname returns the correct IP address.
>>>> Is this due to some configuration issues in zepto-vn-eval/mosatest
>>>> profile?As a workaround I tired to use ifconfig with both
>>>> profiles,
>>>> but
>>>> it seems ifconfig is not returning the correct IP address.
>>>> Is there any command / files which I can used to retrieve the
>>>> hostname
>>>> on compute nodes? I have pasted the console output with both
>>>> profiles
>>>> below. Please let me know if you need more details.
>>>> Thank you
>>>> Emalayan
>>>> =======================With zeptoos profile
>>>> / # hostname
>>>> 172.18.3.19
>>>> / # cat /proc/sys/kernel/hostname
>>>> 172.18.3.19
>>>> / # ifconfig -a
>>>> lo Link encap:Local Loopback
>>>> inet addr:127.0.0.1 Mask:255.0.0.0
>>>> UP LOOPBACK RUNNING MTU:16436 Metric:1
>>>> RX packets:0 errors:0 dropped:0 overruns:0 frame:0
>>>> TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
>>>> collisions:0 txqueuelen:0
>>>> RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
>>>> tun0 Link encap:UNSPEC HWaddr
>>>> 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
>>>> inet addr:192.168.1.64 P-t-P:192.168.1.254 Mask:255.255.255.255
>>>> UP POINTOPOINT RUNNING NOARP MULTICAST MTU:65535 Metric:1
>>>> RX packets:2662 errors:0 dropped:0 overruns:0 frame:0
>>>> TX packets:1772 errors:0 dropped:0 overruns:0 carrier:0
>>>> collisions:0 txqueuelen:500
>>>> RX bytes:140206 (136.9 KiB) TX bytes:125412 (122.4 KiB)
>>>> =======================With zepto-vn-eval/mosatest profile
>>>> /etc # hostname
>>>> (none)
>>>> /etc #
>>>> /etc # cat /proc/sys/kernel/hostname
>>>> (none)
>>>> /etc #
>>>> /etc # ifconfig -a
>>>> eth0 Link encap:Ethernet HWaddr 00:80:46:00:00:00
>>>> BROADCAST MULTICAST MTU:1500 Metric:1
>>>> collisions:0 txqueuelen:1000
>>>> eth1 Link encap:Ethernet HWaddr 00:80:47:00:00:00
>>>> inet6 addr: ::1/128 Scope:Host
>>>> sit0 Link encap:IPv6-in-IPv4
>>>> NOARP MTU:1480 Metric:1
>>>> RX packets:965 errors:0 dropped:0 overruns:0 frame:0
>>>> TX packets:627 errors:0 dropped:0 overruns:0 carrier:0
>>>> RX bytes:50984 (49.7 KiB) TX bytes:50530 (49.3 KiB)
>> Michael Wilde
>> Computation Institute, University of Chicago
>> Mathematics and Computer Science Division
>> Argonne National Laboratory
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
