[Swift-devel] coasters-hosts.pl script
Michael Wilde wilde at mcs.anl.gov
Fri Mar 2 19:27:01 CST 2012
> The first step is to write a simple example (like a cat to cat copy)
> and test it in local mode, say using /tmp/mosa, checking its logs and
> work dir to ensure that direct mode was working as expected. Then try
> the same thing on a vanilla cluster (the UBC cluster would be fine)
> using first /tmp/mosa and then the real /mosa.
I forgot to clarify: do the above test with coaster and provider staging mode, so that there *is* no shared filesystem defined (ie the workdirectory tag in the sites file should be /tmp or /dev/shm)
