[Swift-devel] MPI jobs with plain PBS provider
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Jun  6 09:26:09 CDT 2012
David, adding jobType and count attributes as follows should do what you want:
    <profile namespace="globus" key="count">2</profile>
    <profile namespace="globus" key="jobType">single</profile>
This was added to trunk on May 22, r3412:
Accept jobType value "single" in sites.xml to force a multi-node non-coaster non-JETS PBS job to run a single application.
Test on plain PBS (PADS), not yet tested on Cray PBS.
- Mike
----- Original Message -----
> From: "David Kelly" <davidk at ci.uchicago.edu>
> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Tuesday, June 5, 2012 9:19:49 PM
> Subject: [Swift-devel] MPI jobs with plain PBS provider
> Hello,
> I am trying to run an MPI job with the plain PBS provider (no
> coasters) on Fusion. I'm following the instructions in the user guide,
> section 19.3.1
> (http://www.ci.uchicago.edu/swift/guides/trunk/userguide/userguide.html#_launching_mpi_jobs_from_swift).
> It works well with one node. How can I start only one worker, but
> request multiple nodes? I need something like this in the submit
> script:
> #PBS -l nodes=2:ppn=8
> From looking at the provider, it looks like the value of nodes is
> determined by the internal 'count' variable, which I believe is always
> set to 1 for non-coaster jobs. I can control the ppn with the ppn
> attribute, but as far as I can tell, there is no nodes attribute. Does
> it make sense to add one for MPI jobs like this?
> Here are the files I am testing with:
> sites.xml
> <config>
> <pool handle="fusion">
> <execution jobmanager="local:pbs" provider="pbs" url="none"/>
> <filesystem provider="local" url="none" />
> <profile namespace="globus" key="maxtime">60</profile>
> <profile namespace="globus" key="jobsPerNode">1</profile>
> <profile namespace="globus" key="ppn">8</profile>
> <profile namespace="karajan" key="jobThrottle">5.99</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> <workdirectory>/homes/davidk/swiftwork</workdirectory>
> </pool>
> </config>
> testmpi.swift
> type file;
> app (file r) mpi ()
> mpi;
> file results <"results.tar">;
> results = mpi();
> mpi.sh
> #!/bin/bash
> mpiexec -machinefile $PBS_NODEFILE /home/davidk/testmpi/testmpi
> David
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
