[Swift-devel] Java memory strangeness
    David Kelly
    davidk at ci.uchicago.edu
    Mon Jul  2 16:49:48 CDT 2012
Hello,
I installed Sun Java on a new machine I am working on. When I try to run it I see this:
-bash-3.2$ java -version
Error occurred during initialization of VM
Could not reserve enough space for object heap
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
The machine has 27G of memory free.
When I specify a value of -Xmx it seems to work fine until I get somewhere around between 4 and 8 gigs. From what I've read, the default heap size is 1/4th of the total memory up to 1 gig, so I have no idea why it's failing here.
I can run Swift manually from this machine because the swift shell script explicitly sets the heap size.
But, I run into problems when I use ssh:pbs to the machine.
How is the heap size determined when using ssh/coasters/bootstrapping? I've tried setting SWIFT_MAX_HEAP and COG_OPTS in my bashrc but that didn't seem to help. I might be able to get around this by creating some kind of java wrapper that explicitly sets heap size.. just curious how it currently gets set in this situation.
David
