[Swift-devel] Need pointers to BG/P info for Swift execution
Justin M Wozniak
wozniak at mcs.anl.gov
Fri Jan 27 13:09:05 CST 2012
There are some things on the old wiki site:
http://www.ci.uchicago.edu/wiki/bin/view/SWFT/WebHome
including:
http://www.ci.uchicago.edu/wiki/bin/view/SWFT/BgpCookbook
As we improve these notes, we should move everything to:
https://sites.google.com/site/swiftdevel/sites
Here are my notes from performance runs on the BG/P:
http://www.ci.uchicago.edu/wiki/bin/view/SWFT/PerformanceNotes
All of those tests are in my:
https://svn.mcs.anl.gov/repos/wozniak/collab/cdm
which I can share if you're interested.
Justin
On Fri, 27 Jan 2012, ZHAO ZHANG wrote:
> Hi, Mike
> I am cc'ing Jon here. I am not sure how swift is currently configured on
> BG/P.
> Here are some instructions to run stuff on there.
> On 1/26/2012 3:33 PM, Michael Wilde wrote:
>> Justin, Zhao, All,
>> Its been a long time since I have personally run Swift scripts on the
>> BG/Ps.
>> I am trying to help Jon get started on the BG/P, but I have forgotten some
>> of the basics. Can you point out the info a Swift BG/P user needs
>> regarding:
>> - how to make sure that workers and the swift app() programs they launch
>> have the right Linux environment (ie, full bash, full env, not limited
>> "busybox" tools)
> Please find out in the .sh file in the attachment. To run it, execute "cqsub
> -p MTCScienceApps -q prod-devel -k zepto-vn-eval $PATH/cnip-start.sh" on
> either challenger or surveyor.
>> - how to ssh/telnet to worker nodes
> On surveyor and intrepid,
> Run "cqstat | grep running" or "cqstat -f | grep running", then you get
> 467064 toussain 02:00:00 512 running ANL-R03-M0-512
> Running " /soft/apps/ZeptoOS/bin/listip ANL-R11-M0-512" returns the list of
> the IO nodes
> 172.16.5.9
> 172.16.5.10
> 172.16.5.11
> 172.16.5.12
> 172.16.5.13
> 172.16.5.14
> 172.16.5.15
> 172.16.5.16
> Then you can ssh to those IO nodes.
> On Challenger, it is a bit different,
> Given a job status as following
> 467717 felker 00:30:00 64 running CHR-R00-M1-N08-64
> Running "nslookup R00-M1-N08-J00" returns the IP of the IO node. 172.16.9.49
> in this case.
> On each IO node, it has 64 compute nodes with it. The ip address is from
> 192.168.1.1 to 192.168.1.64.
> From the compute nodes' point of view, the IO node's address is 192.168.1.254
> We have to telnet to those compute nodes.
> You may find the first couple of lines of cnip-start.sh is setting the IP on
> the compute nodes.
> That is the IP on torus network, it is a global network across all compute
> nodes within a single allocation.
> best
> zhao
>> - anything else different from a normal cluster?
>> - tips for working with Cobalt
>> Thanks,
>> - Mike
Justin M Wozniak
