[Swift-devel] command line ssh provider...
Jonathan Monette
jonmon at mcs.anl.gov
Tue Jan 17 17:17:44 CST 2012
Ok. I understand now. Anyways the switch to ProcessBuilder fixed the issue.
On Jan 17, 2012, at 5:12 PM, Mihael Hategan wrote:
> On Tue, 2012-01-17 at 17:08 -0600, Jonathan Monette wrote:
>>> Though now that I think about it, this wasn't strictly necessary since
>>> for the ssh-cl provider, the task environment variables shouldn't be
>>> passed to the ssh subprocess (they go on the command line of the ssh
>>> shell).
>> What do you mean by this? When I saw the command line of the ssh shell no environment variables are being passed.
> 1. java forks ssh
> 2. ssh -> sshd
> 3. sshd forks shell
> There is no point in passing task env vars in (1). You need them
> somewhere in (3).
> You don't see them in the shell command line because they are passed on
> its stdin (i.e. as if typed).
