[Swift-devel] command line ssh provider...
Jonathan Monette jonmon at mcs.anl.gov
Tue Jan 17 13:20:51 CST 2012
Making ssh fail do to an invalid password does not log the stdout/stderr.
2012-01-17 13:19:05,117-0600 INFO  GridExec TASK_DEFINITION: Task(type=JOB_SUBMISSION, identity=urn:0-1-1-1326827944463) is /bin/bash shared/_swiftwrap hostname-c8cjdrlk -jobdir c -scratch  -e /bin/hostname -out hostname.txt -err stderr.txt -i -d  -if  -of hostname.txt -k  -cdmfile  -status provider -a
2012-01-17 13:19:05,123-0600 DEBUG JobSubmissionTaskHandler Job:
	executable: /bin/bash
	arguments:  /home/jonmon/Workspace/Swift/swift.workdir/hostname-20120117-1319-e2aautsf/shared/_swiftwrap hostname-c8cjdrlk -jobdir c -scratch  -e /bin/hostname -out hostname.txt -err stderr.txt -i -d  -if  -of hostname.txt -k  -cdmfile  -status provider -a
	stdout:     null
	stderr:     null
	directory:  /home/jonmon/Workspace/Swift/swift.workdir/hostname-20120117-1319-e2aautsf
	batch:      false
	redirected: false
	attributes: null
	env:        SWIFT_GEN_SCRIPTS=1
On Jan 17, 2012, at 12:48 PM, Mihael Hategan wrote:
> On Tue, 2012-01-17 at 11:33 -0600, Jonathan Monette wrote:
>> I am assuming that I have to get the sshcl provider to fail again for
>> the stdout/stderr to be recorded?
> Yes!
>>  I typed the correct password in and this is what showed up:
>> 2-01-17 11:25:16,375-0600 DEBUG JobSubmissionTaskHandler Job:
>> 	arguments:  /home/jonmon/Workspace/Swift/swift.workdir/hostname-20120117-1125-ora1c4k1/shared/_swiftwrap hostname-km209rlk -jobdir k -scratch  -e /bin/hostname -out hostname.txt -err stderr.txt -i -d  -if  -of hostname.txt -k  -cdmfile  -status provider -a
>> 	stdout:     null
>> 	stderr:     null
>> 	directory:  /home/jonmon/Workspace/Swift/swift.workdir/hostname-20120117-1125-ora1c4k1
>> 	batch:      false
>> 	redirected: false
>> 	attributes: null
>> This is what shows up in ps:
>> jonmon   19162  0.0  0.0  59456  3344 pts/0    S+   11:25   0:00 ssh -v bridled.ci.uchicago.edu /bin/bash -s
>> so -v is being used in the ssh command but Swift isn't recording the output.
> Right. Only in the case of failure is it logged.
>> I have also tried entering in the wrong password but Swift just keeps
>> asking for the password until I type the correct one in.
> It's not swift asking for the password, but ssh. You have to mistype it
> enough times so that ssh will fail.
>> I see in the JobSubmissionTaskHandler file there is a way to specify a
>> username.  In the sites file I use the line: <execution
>> provider="ssh-cl" username="jonmon" url="bridled.ci.uchicago.edu"/>
> Yeah, I'll remove that. Use ~/.ssh/config instead.
>> but the username is not used, I do not see the -l in the command line of the sshcl provider.  I wanted to try providing a username to the ssh command to see if that some how made it realize to use the agent set up for the user jonmon.
