[Swift-devel] askpass for command line ssh provider?
Jonathan Monette
jonmon at mcs.anl.gov
Mon Jan 16 12:18:53 CST 2012
On Jan 16, 2012, at 10:44 AM, Michael Wilde wrote:
>> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
>> To: "Michael Wilde" <wilde at mcs.anl.gov>
>> Cc: "Mihael Hategan" <hategan at mcs.anl.gov>, "Swift Devel" <swift-devel at ci.uchicago.edu>
>> Sent: Monday, January 16, 2012 10:31:21 AM
>> Subject: Re: [Swift-devel] askpass for command line ssh provider?
>> I always thought the solution to the OTP situation was to set up a
>> master channel. Inside a portal this is easy. The portal knows which
>> sites are used and which sites require a OTP. The portal can then set
>> up a master channel. For the situation for the agents, the portal can
>> always create the agent itself after prompting for a password once
>> can't it? In both scenarios the portal creates the mechanisms to limit
>> the number of passwords that are required.
> I think I agree with this - its similar to what I wrote below.
> Im not sure I fully understand yet when you need a master channel and when you want an agent. I *think* that you want a master channel whenever multi-hop SSH is needed, and an agent in the rest of the cases.
You also want a master channel for the OTP situation I believe.
> There also might be some subtleties related to the various forward and reverse tunnels we've needed to set up for various coaster configurations in clouds and other firewalled environments.
>> For Swift, I do not think that these solutions work since Swift needs
>> to be more general(maybe creating agent approach but that won't work
>> for OTP situations).
> Can you clarify what you mean here? It seems that are 2 issues to work through:
> - can we and should we create a useful set of manually-executable scripts for Swift users that encapsulate the various useful ssh configurations and incantations?
> I hope the answer to this is "yes" to both.
> - Should the swift command invoke any of these scripts automatically from the ssh-cl provider (or some other point in processing)?
> I am less sure about the answer to this. I think the best approach is to initially make this manual, and show the user how to create wrapper scripts around the swift command this set up the necessary ssh access. Or possible, command line options? Or a .swift-ssh-setup rc file run by the swift command?
If we require the user to set up the ssh configuration manually, either himself or using some scripts we provide, then the problem is solved but if we want Swift to set up the ssh configuration for the user then we run into issues. I think a rc file would be necessary where the user specifies what type of machine they are trying to access. This way Swift can determine which set of executable scripts it needs to use. The reason I said this may not work for Swift is because how does Swift know whether the machine is it trying to access uses OTP(BlueGene) or needs to be multi-hopped because it is behind a firewall(MCS cluster).
I think doing the manual approach is best for now.
> - Mike
>> On Jan 16, 2012, at 10:07 AM, Michael Wilde wrote:
>>> Was: Re: [Swift-devel] command line ssh provider...
>>> After a bit more thought, it seems that enabling the ssh-cl provider
>>> to prompt for passwords is perhaps not a required feature.
>>> We will for example need to access many systems that needs a one
>>> time password.
>>> But its likely that such mechanisms need to be set up outside of
>>> Swift (or at least outside the main line of the provider), using
>>> agents or master channels, else the user would get multiple password
>>> prompts per endpoint.
>>> For now, we can do this outside of Swift proper (ie in the various
>>> portals, ideally via scripts that we package in swift/bin which can
>>> be used by both command line users and by portal code).
>>> Later we can consider if its reasonable to make the ssh-cl provider
>>> smart enough to invoke such channel or agent setup scripts
>>> automatically when needed.
>>> - Mike
>>>> From: "Mihael Hategan" <hategan at mcs.anl.gov>
>>>> Cc: "Ben Clifford" <benc at hawaga.org.uk>, "Swift Devel"
>>>> Sent: Friday, January 13, 2012 6:09:18 PM
>>>> Subject: Re: [Swift-devel] command line ssh provider...
>>>> On Fri, 2012-01-13 at 18:00 -0600, Michael Wilde wrote:
>>>>> Another good test is to access eg surveyor, and intrepid using an
>>>>> OTP via ssh-cl.
>>>> A word of caution there: if the ssh client asks for the password on
>>>> the
>>>> command line (instead of through ssh-askpass or some other gui),
>>>> things
>>>> won't work very well. It might be possible to add some detection
>>>> for
>>>> that in the provider, but that's not a high priority given that
>>>> there
>>>> is
>>>> a workaround (askpass).
>>> Michael Wilde
>>> Computation Institute, University of Chicago
>>> Mathematics and Computer Science Division
>>> Argonne National Laboratory
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Michael Wilde
