[Swift-devel] provider.staging.pin.swiftfiles feature
Justin M Wozniak wozniak at mcs.anl.gov
Tue Jan 3 09:50:33 CST 2012
Some notes about this are at:
http://www.ci.uchicago.edu/wiki/bin/view/SWFT/CoastersPinned
I should move this to the new site and bring it into the guide if it is
still useful.
The point of this is to avoid recopying small Swift system files into
local storage for each job.  If you set that property and use Coasters
with provider staging, it should just work.
The example on that page shows that _swiftwrap.staging is copied into
local (RAM?) disk and "pinned"- worker.pl remembers that it is there and
does not transfer it again.
 	Justin
On Fri, 23 Dec 2011, Ketan Maheshwari wrote:
> I was looking into the provider staging trying to address the issue of
> having files accessed directly at remote sites skipping provider staging (
> https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=676) .
> I see the option provider.staging.pin.swiftfiles of swift.properties
> appears into vdl-int.k as well as worker.pl but couldn't quite got at what
> is the functionality.
> Could someone indicate this.
Justin M Wozniak
