[Swift-devel] [Swift-user] coaster-service.conf
    Emalayan Vairavanathan
    svemalayan at yahoo.com
    Mon Feb 27 21:06:33 CST 2012
Hi Jon
Thank you very much. Please find my ans below.
I assume you mean the "-k" option in the cqsub command.
What I meant was "--kernel" option in qsub.
Are you using your own checkout of trunk or the one in Justin's home directory?
Code from Justin's home directory
Emalayan
To: Emalayan Vairavanathan <svemalayan at yahoo.com>
Cc: swift user <swift-user at ci.uchicago.edu>; "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>; MosaStore <mosastore at googlegroups.com>
Sent: Monday, 27 February 2012 6:13 PM
Subject: Re: [Swift-user] coaster-service.conf
I assume you mean the "-k" option in the cqsub command.  So currently this is hard coded into the start-coaster-service script, it always uses zeptoos.  I have made a quick change that uses a KERNEL variable that needs to be set in the coaster-service.conf file.  Are you using your own checkout of trunk or the one in Justin's home directory?
On Feb 27, 2012, at 7:33 PM, Emalayan Vairavanathan wrote:
Hi All,
>When I launch coaster-service, it allocates job with default kernel profile "zeptoos". I want to change the profile to"zepto-vn-eval/mosatest".
>How can I do this ? Is there any configuration parameter available to change qsub command?
>If so how I can specify / pass this parameter?  (via start-coaster-service's command-line parameter or via a setting in coaster-service.conf)
>Also could you please tell me the exact format ? Please point to me a document if there is any.
>Thank you
>Emalayan
>_______________________________________________
>Swift-user mailing list
>Swift-user at ci.uchicago.edu
>https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120227/15224ca9/attachment.html>
