[Swift-devel] cybershake hangs in the latest Swift 0.93 does not	hang in a previous rel
    David Kelly
    davidk at ci.uchicago.edu
    Wed Feb 22 09:12:14 CST 2012
I changed to r5609 to match Ketan's working version, but am still getting the same errors.
[davidk at communicado run]$ swift -version
no sites file specified, setting to default: /home/davidk/swift-0.93/cog/modules/swift/dist/swift-svn/etc/sites.xml
Swift 0.93 swift-r5609 cog-r3361
I'll dig through the logs a bit and see if I can narrow it down. Here is the message I get via stdout.
No events in 10s.
Registered futures:
string[] var_str  Closed, 242 elements, no listeners
string[] var_str  Closed, 8 elements, no listeners
string[] var_str  Closed, 18 elements, no listeners
string[] var_str  Closed, 32 elements, no listeners
string[] var_str  Closed, 2 elements, no listeners
string[] var_str  Closed, 50 elements, no listeners
string[] var_str  Closed, 200 elements, no listeners
SgtDim sgt_var - F/sgt_var..y:SgtDim - Open
string[] var_str  Closed, 128 elements, no listeners
string[] var_str  Closed, 72 elements, no listeners
Waiting threads:
0-13-118-6
0-13-52-6
0-13-30-6
0-13-139-6
0-13-194-6
0-13-24-6
0-13-127-6
0-13-149-6
0-13-42-6
0-13-138-6
0-13-174-6
0-13-89-6
0-13-36-6
0-13-156-6
0-13-53-6
0-13-152-6
0-13-90-6
0-13-158-6
0-13-132-6
0-13-136-6
0-13-87-6
0-13-92-6
0-13-182-6
0-13-9-6
0-13-29-6
0-13-60-6
0-13-70-6
0-13-12-6
0-13-81-6
0-13-178-6
0-13-49-6
0-13-97-6
0-13-65-6
0-13-145-6
0-13-135-6
0-13-190-6
0-13-11-6
0-13-163-6
0-13-155-6
0-13-16-6
0-13-154-6
0-13-167-6
0-13-173-6
0-13-166-6
0-13-0-6
0-13-191-6
0-13-37-6
0-13-17-6
0-13-85-6
0-13-79-6
0-13-134-6
0-13-176-6
0-13-125-6
0-13-38-6
0-13-187-6
0-13-35-6
0-13-171-6
0-13-88-6
0-13-131-6
0-13-106-6
0-13-55-6
0-13-168-6
0-13-147-6
0-13-148-6
0-13-99-6
0-13-34-6
0-13-2-6
0-13-100-6
0-13-48-6
0-13-5-6
0-13-69-6
0-13-80-6
0-13-153-6
0-13-122-6
0-13-105-6
0-13-113-6
0-13-26-6
0-13-124-6
0-13-32-6
0-13-123-6
0-13-98-6
0-13-170-6
0-13-28-6
0-13-22-6
0-13-162-6
0-13-15-6
0-13-64-6
0-13-13-6
0-13-111-6
0-13-66-6
0-13-43-6
0-13-19-6
0-13-78-6
0-13-157-6
0-13-57-6
0-13-142-6
0-13-151-6
0-13-3-6
0-13-140-6
0-13-76-6
0-13-188-6
0-13-91-6
0-13-75-6
0-13-47-6
0-13-50-6
0-13-41-6
0-13-40-6
0-13-21-6
0-13-193-6
0-13-102-6
0-13-59-6
0-13-189-6
0-13-31-6
0-13-197-6
0-13-110-6
0-13-4-6
0-13-20-6
0-13-185-6
0-13-137-6
0-13-121-6
0-13-180-6
0-13-169-6
0-13-58-6
0-13-116-6
0-13-45-6
0-13-93-6
0-13-146-6
0-13-164-6
0-13-101-6
0-13-179-6
0-13-115-6
0-13-23-6
0-13-94-6
0-13-44-6
0-13-177-6
0-13-10-6
0-13-84-6
0-13-186-6
0-13-150-6
0-13-198-6
0-13-195-6
0-13-14-6
0-13-143-6
0-13-63-6
0-13-77-6
0-13-51-6
0-13-25-6
0-13-172-6
0-13-18-6
0-13-68-6
0-13-159-6
0-13-128-6
0-13-104-6
0-13-141-6
0-13-6-6
0-13-126-6
0-13-108-6
0-13-1-6
0-13-199-6
0-13-175-6
0-13-120-6
0-13-119-6
0-13-192-6
0-13-183-6
0-13-103-6
0-13-133-6
0-13-184-6
0-13-161-6
0-13-196-6
0-13-112-6
0-13-129-6
0-13-33-6
0-13-72-6
0-13-74-6
0-13-39-6
0-13-160-6
0-13-54-6
0-13-117-6
0-13-114-6
0-13-95-6
0-13-165-6
0-13-181-6
0-13-46-6
0-13-27-6
0-13-109-6
0-13-130-6
0-13-144-6
0-13-82-6
0-13-67-6
0-13-8-6
0-13-62-6
0-13-73-6
0-13-56-6
0-13-86-6
0-13-7-6
0-13-107-6
0-13-83-6
0-13-71-6
0-13-96-6
0-13-61-6
----- Original Message -----
> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> To: "Mihael Hategan" <hategan at mcs.anl.gov>
> Cc: "David Kelly" <davidkelly999 at gmail.com>, "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Monday, February 20, 2012 4:42:10 PM
> Subject: [Swift-devel] cybershake hangs in the latest Swift 0.93 does not hang in a previous rel
> Mihael,
> Reporting a case of deadlock/hang occurring in the recent swift 0.93
> update:
> I've been working on the cybershake script with David today and it
> seems that the script hangs at around the same on David's Swift
> installation which is:
> Swift 0.93 swift-r5658 cog-r3361
> I successfully tested the same configuration with my swift
> installation which is a bit older release:
> Swift 0.93 swift-r5609 (swift modified locally) cog-r3361 (cog
> modified locally)
> The log for the hanged version is:
> http://ci.uchicago.edu/~ketan/postproc-20120220-1617-hvcmjs71.log
> The jstack for the hang version is:
> http://ci.uchicago.edu/~ketan/cybershake.jstack
> The log for the successful run is:
> http://ci.uchicago.edu/~ketan/postproc-20120220-1454-lfog5xu1.log
> Regards, --
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
