[Swift-devel] Command Reply Timeout
    Jonathan Monette
    jonmon at mcs.anl.gov
    Tue Feb 21 13:08:41 CST 2012
I see….thanks.  I will figure out what happened.
On Feb 21, 2012, at 1:00 PM, Mihael Hategan wrote:
> It's saying that a connection between the coaster service and a worker
> isn't going quite right.
> On Tue, 2012-02-21 at 12:56 -0600, Jonathan Monette wrote:
>> What does this mean?
>>   Command Command(54, HEARTBEAT): handling reply timeout; sendReqTime=120221-185033.459, sendTime=700101-000000.000, now=120221-185233.649, channel=SC-0221-330346-000016-000001
>> I see these lines sprinkled throughout my swift run and in the logs are log4j level WARN.  What is it trying to tell me?  Should I be worried?  I cannot tell if my workflow is making progress or not.  It looked like it was even with these messages popping up but now I am not sure if it is.  What is the above line saying?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
