[Swift-devel] Walltime exceeded error
    Jonathan Monette
    jonmon at mcs.anl.gov
    Mon Feb 20 16:27:30 CST 2012
Correction, Beagle does have jstack.  Do not know why I thought it did not have it.
On Feb 20, 2012, at 4:26 PM, Jonathan Monette wrote:
> No.  This was a run Ketan did a while back.  I have been using this as a reference when trying to re-create the issue with a simple catsnsleep job.
> This run was also done on Beagle using the pre-installed java package, which does not have jstack.
> On Feb 20, 2012, at 4:24 PM, Mihael Hategan wrote:
>> I'm not sure if I asked this, but did you happen to get a jstack of the
>> hanging swift?
>> On Mon, 2012-02-20 at 16:19 -0600, Jonathan Monette wrote:
>>> No.  The last run was run using Beagle.  That is the more interesting one.  That shows jobs failed but the "Failed but can retry" count was not printed very often.  You can see that in the swift.out file.  Eventually the workflow just hung and the hang checker kicked in.  You can also see that Swift got stuck in the initializing state with a count of 61.
>>> On Feb 20, 2012, at 4:16 PM, Mihael Hategan wrote:
>>>> On Mon, 2012-02-20 at 16:14 -0600, Jonathan Monette wrote:
>>>>> /gpfs/pads/swift/jonmon/Swift/tests/catsnsleep                                 <----- on /gpfs/pads
>>>>> /home/jonmon/public_html/Swift/bugs/SciColSim/run002             <----- on any CI machine
>>>> Ok. Sorry. I thought the last one was on beagle.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
