[Swift-devel] tc and sites file debugging
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Fri Feb 10 15:19:53 CST 2012
There should be a message for that case as well.  Which branch are you
using?
On Fri, 10 Feb 2012, Jonathan Monette wrote:
> It is set.  So, if not sites file or tc file shows up in the logs, that is a pretty good indication that they defaulted to the ones provided by Swift correct?
> On Feb 10, 2012, at 3:14 PM, Justin M Wozniak wrote:
>> Just set:
>> log4j.logger.swift.textfiles=DEBUG
>>> What log4j properties do I have to turn on to see what the path is to the tc and sites file I am using in a Swift run?  I keep getting an error saying that the application is not in my tc file for any of the site pool entries.  I just want to see if Swift is grabbing the write files.
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>> Justin M Wozniak
Justin M Wozniak
