[Swift-devel] multiple proxy support
Michael Wilde
wilde at mcs.anl.gov
Thu Aug 2 04:44:53 CDT 2012
Beautiful - thanks, Mihael!
David, can you test this using a CI proxy on PADS and an LCRC proxy on Fusion (or ALCF proxy on Eureka)?
Kyle, can we also test against the CMTS GCMU server? If we can demonstrate that with globus-url-copy then it should now work from Swift.
Mihael, how do we handle the issue of CA certs? These all need to be in the X509_CERT_DIR/X509_CA_DIR of the swift client process, I assume?
- Mike
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Thursday, August 2, 2012 1:56:08 AM
> Subject: [Swift-devel] multiple proxy support
> There is code now in trunk to allow different GSI proxies to be used
> for
> different hosts.
> It works as follows:
> create ~/.globus/proxy.mapping and populate it with lines of the form
> "hostname=/path/to/proxy"
> GSI based operations (the kind from cog4, not purely jglobus) going to
> "hostname" will try to load the proxy from "/path/to/proxy" instead of
> the default "/tmp/x509_u<userid>".
> (this is as of cog trunk r3444).
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
