[Swift-devel] coaster io with NIO.
    David Kelly
    davidk at ci.uchicago.edu
    Tue Apr 10 17:25:59 CDT 2012
Yep, I gave it a try with automatic coasters, but am still seeing the timeouts.
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Tuesday, April 10, 2012 4:32:06 PM
> Subject: Re: [Swift-devel] coaster io with NIO.
> I'll fix that. In the mean time, can you try with automatic coasters?
> On Tue, 2012-04-10 at 03:56 -0500, David Kelly wrote:
> > I seem to having some issues with this version. When I run
> > "coaster-service -nosec -portfile /tmp/tmp.zdo0L0LNoK -localportfile
> > /tmp/tmp.ZKOZqdZy9L -passive", I get this:
> > Error starting coaster service: null
> > java.lang.NullPointerException
> > 	at
> > 	org.globus.cog.abstraction.coaster.service.LocalTCPService.getPort(LocalTCPService.java:158)
> > 	at
> > 	org.globus.cog.abstraction.coaster.service.CoasterPersistentService.writePorts(CoasterPersistentService.java:188)
> > 	at
> > 	org.globus.cog.abstraction.coaster.service.CoasterPersistentService.main(CoasterPersistentService.java:145)
> > When I specify the port numbers, I can connect, but nothing seems to
> > happen.
> > David
> > > To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > > Sent: Tuesday, April 10, 2012 2:17:08 AM
> > > On Mon, 2012-04-09 at 08:06 -0700, Mihael Hategan wrote:
> > > > I'll commit the changes today so that you guys can test it.
> > > > Works
> > > > fine
> > > > on localhost so far.
> > > Darn. I was 15 minutes late on that.
> > > Anyway, cog trunk r3370.
> > > Let me know how this works out. As I said, I did some preliminary
> > > testing locally, but various other combinations may be a bit shaky
> > > at
> > > this point.
> > > Mihael
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
