[Swift-devel] Swift did not make progress with high throtteling rate
    Emalayan Vairavanathan
    svemalayan at yahoo.com
    Tue Apr 10 13:41:43 CDT 2012
Hi All,
I tired to run my pipeline-swift benchmark on GPFS+PVFS with 128 compute nodes (Surveyor), JOB_THROTTLE = 1000 and JOBS_PER_NODE = 4.
I used GPFS as the central storage and PVFS as the intermediate storage. The benchmark did not make any progress and I found the following messages in the log file. (This happened even with MosaStore)
2012-04-10 18:18:36,710+0000 WARN  HangChecke No events in 10s.
2012-04-10 18:18:36,717+0000 WARN  HangChecker
Registered futures:
file stage_2_output - F/stage_2_output[95]:file - Open
file stage_1_output - F/stage_1_output[85]:file - Open
file stage_3_output - F/stage_3_output[62]:file - Open
file stage_3_output - F/stage_3_output[44]:file - Open
file stage_1_output - F/stage_1_output[4]:file - Open
file stage_2_output - F/stage_2_output[3]:file - Open
file input_data - F/input_data[121]:file - Open
file stage_1_output - F/stage_1_output[113]:file - Open
file stage_1_output - F/stage_1_output[98]:file - Open
I am using the swift version that I took from Justin's home directory 3 weeks before.
Do you have any idea ? Does swift has problem with high throttling rate / jobs-per-node ? I have attached swift log file and the benchmark with this mail. I highly appreciate your suggestions.
Thank you
Emalayan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120410/0698ba44/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120410/0698ba44/attachment.bin>
