[Swift-devel] coaster io with NIO.
    David Kelly
    davidk at ci.uchicago.edu
    Tue Apr 10 03:56:11 CDT 2012
I seem to having some issues with this version. When I run "coaster-service -nosec -portfile /tmp/tmp.zdo0L0LNoK -localportfile /tmp/tmp.ZKOZqdZy9L -passive", I get this:
Error starting coaster service: null
java.lang.NullPointerException
	at org.globus.cog.abstraction.coaster.service.LocalTCPService.getPort(LocalTCPService.java:158)
	at org.globus.cog.abstraction.coaster.service.CoasterPersistentService.writePorts(CoasterPersistentService.java:188)
	at org.globus.cog.abstraction.coaster.service.CoasterPersistentService.main(CoasterPersistentService.java:145)
When I specify the port numbers, I can connect, but nothing seems to happen.
David
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Tuesday, April 10, 2012 2:17:08 AM
> Subject: Re: [Swift-devel] coaster io with NIO.
> On Mon, 2012-04-09 at 08:06 -0700, Mihael Hategan wrote:
> > I'll commit the changes today so that you guys can test it. Works
> > fine
> > on localhost so far.
> Darn. I was 15 minutes late on that.
> Anyway, cog trunk r3370.
> Let me know how this works out. As I said, I did some preliminary
> testing locally, but various other combinations may be a bit shaky at
> this point.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
