[Swift-devel] Join function?
    Jonathan Monette
    jonmon at mcs.anl.gov
    Tue Apr  3 13:47:10 CDT 2012
Ok.  I will add what I know.
On Apr 3, 2012, at 1:45 PM, Michael Wilde wrote:
> Best way to help is to create a developer note in the swiftdevel site describing what you know about how to do this, with an existing example.
> Thanks,
> - Mike
>> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
>> To: "Michael Wilde" <wilde at mcs.anl.gov>
>> Cc: "David Kelly" <davidk at ci.uchicago.edu>, "swift-devel at ci.uchicago.edu Devel" <swift-devel at ci.uchicago.edu>
>> Sent: Tuesday, April 3, 2012 1:42:47 PM
>> Subject: Re: [Swift-devel] Join function?
>> I was just looking into how hard it would be to add an @join function
>> to Swift that does what David describes. I do not think it will be too
>> difficult. So if David wants to try I can help if he would like.
>> On Apr 3, 2012, at 1:40 PM, Michael Wilde wrote:
>>> You might be able to write strjoin() as a recursive Swift function.
>>> It would also be a good exercise for you to add it as a new
>>> primitive, David - as we are rather scanty n string and math
>>> functions.
>>> - Mike
>>>> From: "David Kelly" <davidk at ci.uchicago.edu>
>>>> To: "Jonathan Monette" <jonmon at mcs.anl.gov>
>>>> Cc: "swift-devel at ci.uchicago.edu Devel"
>>>> Sent: Tuesday, April 3, 2012 1:33:06 PM
>>>> I think that would work, but it requires knowing the number of
>>>> elements.
>>>>> To: "David Kelly" <davidk at ci.uchicago.edu>
>>>>> Sent: Tuesday, April 3, 2012 1:21:32 PM
>>>>> So @strcat(a[0],":", a[1], ":", a[2], ":", a[3]); does not work?
>>>>> That
>>>>> is the only swift way I can think of to make it work. The only
>>>>> other
>>>>> approach is to use an app call to a perl/python script.
>>>>> On Apr 3, 2012, at 1:02 PM, David Kelly wrote:
>>>>>> Hello,
>>>>>> Is there a way to concatenate all elements of an array into a
>>>>>> single
>>>>>> string? I would also like to define a separator between elements.
>>>>>> I
>>>>>> was thinking of something similar to Perl's join function.
>>>>>> If I have:
>>>>>> string a[];
>>>>>> a[0] = "this";
>>>>>> a[1] = "is";
>>>>>> a[2] = "a";
>>>>>> a[3] = "test";
>>>>>> How can I get it into "this is a test" or "this:is:a:test"?
>>>>>> @strcat
>>>>>> returns a reference. I can tracef with %q and get
>>>>>> "[this,is,a,test]", but it doesn't give me any control over the
>>>>>> formatting as far as I know.
>>>>>> I could call a shell script to do this, just wondering if there
>>>>>> was
>>>>>> another way.
>>>>>> David
>>>>>> _______________________________________________
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>>>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>> Michael Wilde
>>> Computation Institute, University of Chicago
>>> Mathematics and Computer Science Division
>>> Argonne National Laboratory
> Michael Wilde
