[Swift-devel] hanging in trunk
    Jonathan Monette
    jonmon at mcs.anl.gov
    Tue Apr  3 11:42:48 CDT 2012
Ok.  Just reran it with Sun Java.  Still hung.  Tar ball located at ~jonmon/SciColSim-hang-trunkSun.tar.gz
Again, jstack log provided.
On Apr 3, 2012, at 11:33 AM, Jonathan Monette wrote:
> I just realized that this was with OpenJDK.  I am not sure if it matters but I will try again with a SunJava release.
> On Apr 3, 2012, at 11:30 AM, Jonathan Monette wrote:
>> The workflow still hung in trunk.  I tar balled the run directory and put it at ~jonmon/SciColSim-hang-trunk2.tar.gz on the ci network(my public_html directory seems to be down).  I captured  another jstack log.
>> On Apr 3, 2012, at 11:07 AM, Mihael Hategan wrote:
>>> On Tue, 2012-04-03 at 10:38 -0500, Jonathan Monette wrote:
>>>> You were correct.  The workflow still hung it just took longer in the run I ran.
>>>> So this is what I will do for my the SciColSim app.  I will port the socket and pipe fix to the 0.93 branch and compile my own release for it while the issue is worked out in trunk.  When trunk is believed to be fixed, let me know and I can do my testing.
>>> Oh, I committed the fix to trunk last night.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
