[Swift-devel] persistent coasters gridftp provider fails with	error 500
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Sep 22 22:41:36 CDT 2011
Sorry, the previous test meant /bin/bash is on Bridled. This is the correct
one:
[bridled:~]$ globus-job-run cit-gatekeeper.ultralight.org /bin/sh -c
'/bin/bash -c /bin/hostname'
cithep231.ultralight.org
Is your workdir on a shared filesystem?
Workdir on this site is : /raid2/osg-data/engage/scec/swift_scratch
I tried /tmp: no changes in the behavior.
> On Thu, 2011-09-22 at 21:10 -0500, Ketan Maheshwari wrote:
> > On Thu, Sep 22, 2011 at 6:03 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> >         Does that machine have /bin/bash?
> > yes.
> > [bridled:catsn-condor]$ globus-job-run
> > cit-gatekeeper.ultralight.org /bin/bash -c '/bin/hostname'
> >         The failure to transfer the wrapper log is normal, since the
> >         wrapper
> >         didn't actually run, but it is not the source of the problem.
> >         On Thu, 2011-09-22 at 15:56 -0500, Ketan Maheshwari wrote:
> >         > Hi Mihael,
> >         > I was trying to use persistent coasters on OSG with gridFTP
> >         as
> >         > provider. The script catsn is intended to transfer one small
> >         file
> >         > (<1MB) to an OSG site
> >         (gsiftp://cit-gatekeeper.ultralight.org).
> >         > However, I see that the script fails. The stdout message is:
> >         > Failed to transfer wrapper log for job cat-tyxj0agk
> >         > Progress:  time: Thu, 22 Sep 2011 15:44:35 -0500  Failed:1
> >         > Exception in cat:
> >         > Arguments: [gpfs/pads/swift/ketan/indir1file/data0000.txt]
> >         > Host: CIT_CMS_T2__cit-gatekeeper.ultralight.org
> >         > Directory:
> >         catsngridftp-20110922-1544-brgdcf5d/jobs/t/cat-tyxj0agk
> >         > stderr.txt:
> >         > stdout.txt:
> >         > Caused by: null
> >         > Caused by:
> >         org.globus.cog.abstraction.impl.common.execution.JobException:
> >         Job
> >         > failed with an exit code of 127
> >         > Final status:  time: Thu, 22 Sep 2011 15:44:35 -0500
> >          Failed:1
> >         > The following errors have occurred:
> >         > 1. Job failed with an exit code of 127
> >         > Looking at the log it says the following error:
> >         > 2011-09-22 15:44:35,716-0500 DEBUG vdl:transferwrapperlog
> >         Exception
> >         > for wrapper log failure from
> >         > catsngridftp-20110922-1544-brgdcf5d/info/t on
> >         > eper.ultralight.org: null
> >         > Caused by:
> org.globus.cog.abstraction.impl.file.IrrecoverableResourceException:
> >         > Exception in getFile
> >         > Caused by:
> >         org.globus.cog.abstraction.impl.file.FileResourceException:
> >         > Failed to retrieve file information
> >         > about /raid2/osg-data/engage/scec/swift_scratch/catsngridf
> >         > tp-20110922-1544-brgdcf5d/info/t/cat-tyxj0agk-info
> >         > Caused by: org.globus.ftp.exception.ServerException: Server
> >         refused
> >         > performing the request. Custom message: Server refused MLST
> >         command
> >         > (error code 1) [Nested except
> >         > ion message:  Custom message: Unexpected reply: 500-Command
> >         failed :
> >         > globus_gridftp_server_file.c:globus_l_gfs_file_stat:389:
> >         > 500-System error in stat: No such file or directory
> >         > 500-A system call failed: No such file or directory
> >         > 500 End.] [Nested exception is
> >         > org.globus.ftp.exception.UnexpectedReplyCodeException:
> >          Custom
> >         > message: Unexpected reply: 500-Command failed :
> >         > 500 End.]
> >         > 2011-09-22 15:44:35,719-0500 INFO  vdl:execute END_FAILURE
> >         > thread=0-6-0-1 tr=cat
> >         > 2011-09-22 15:44:35,720-0500 INFO  vdl:execute Exception in
> >         cat:
> >         > Directory:
> >         > I manually tried to transfer files of small sizes to and
> >         from pads to
> >         > the site in question and it worked ok.
> >         > The complete log for this run is:
> http://www.ci.uchicago.edu/~ketan/catsngridftp-20110922-1544-brgdcf5d.log
> >         > Could you kindly study the log and give any clues as to what
> >         is going
> >         > on.
> >         > Regards,
> >         > Ketan
> > Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110922/b6288c24/attachment.html>
