[Swift-devel] swift 0.93 deadlock
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Sep 22 14:03:23 CDT 2011
I'm not sure what's going on there. Basically the very first command
that is run after a channel is established in order to configure various
parameters is timing out. I've never seen this before.
Maybe having debug statements from the service might help. You'll need
to figure out what log4j.properties the service is using and hack that
to display debug messages for:
org.globus.cog.karajan.workflow.service
and
org.globus.cog.abstraction.impl.execution.coaster
Let me know if you have trouble with that.
Mihael
On Thu, 2011-09-22 at 08:42 -0500, David Kelly wrote:
> I tried re-running the script yesterday. It ran for approximately 20 hours before the coaster channel died and I saw a bunch of timeout errors in the logs. I'm not sure if this is a bug or if there was some type of network/service disruption. The worker scripts and coaster service are still running but no more work is being done. I did not run into any of the previous deadlock issues.
> http://www.ci.uchicago.edu/~davidk/swat5/cce_ua-20110922-0411-x8yogrt8.log
> http://www.ci.uchicago.edu/~davidk/swat5/coaster.log
> David
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > To: "David Kelly" <davidk at ci.uchicago.edu>
> > Cc: "swift-devel Devel" <swift-devel at ci.uchicago.edu>, "Papia Rizwan" <papia.rizwan at gmail.com>, "Michael Wilde"
> > <wilde at mcs.anl.gov>
> > Sent: Wednesday, September 21, 2011 2:08:58 AM
> > Subject: Re: [Swift-devel] swift 0.93 deadlock
> > Fix in r5143. Please test.
> > On Mon, 2011-09-19 at 22:20 -0500, David Kelly wrote:
> > > I tried today with the 0.93 update. It ran for approximately 7 hours
> > > before freezing. It looks to be happening in a different place this
> > > time.
> > > http://www.ci.uchicago.edu/~davidk/swat4/jstack.log
> > > http://www.ci.uchicago.edu/~davidk/swat4/cce_ua-20110919-1955-h7t8iui2.log
> > > David
> > > > To: "Michael Wilde" <wilde at mcs.anl.gov>
> > > > Cc: "David Kelly" <davidk at ci.uchicago.edu>, "swift-devel Devel"
> > > > Sent: Saturday, September 17, 2011 11:36:25 PM
> > > > I have a tentative fix in the branch and trunk. Revisions 5123 and
> > > > 5124,
> > > > respectively. Please let me know how that works out.
> > > > Mihae
> > > > On Fri, 2011-09-16 at 11:50 -0500, Michael Wilde wrote:
> > > > > David and Papia, can you report to the list what the status is
> > > > > of
> > > > > running the SWAT app?
> > > > > - I understand that Mihael will work on the 0.93 deadlock fix
> > > > > this
> > > > > weekend, which is great.
> > > > > - I understand that its happening on trunk as well
> > > > > - Papia, can you try to "perturb" the Swift code in the hopes
> > > > > that
> > > > > some equivalent but different code doesnt trip into the same
> > > > > bug? Ie
> > > > > try a different mapper, different variable strategy (ie arrays
> > > > > vs
> > > > > scalars, structs vs separate vars) just to see if you can work
> > > > > around this? Or, put in some shell logic to catch the hang and
> > > > > kill
> > > > > and re-run (or resume) Swift? if you just kill a hung script and
> > > > > then resume it, will it work? We could maybe alter the hang
> > > > > checker
> > > > > to kill swift on its own, with a return code or message that you
> > > > > could use to trigger a resume.
> > > > > Mike
> > > > > > From: "David Kelly" <davidk at ci.uchicago.edu>
> > > > > > Sent: Thursday, September 15, 2011 4:34:02 PM
> > > > > > I was able to get it running on PADS with trunk. I ran into
> > > > > > the
> > > > > > same
> > > > > > issue.
> > > > > > http://www.ci.uchicago.edu/~davidk/swat3/jstack.log
> > > > > > http://www.ci.uchicago.edu/~davidk/swat3/cce_ua-20110915-1617-sd4svyo2.log
> > > > > > David
> > > > > > > "Papia
> > > > > > > Sent: Thursday, September 15, 2011 2:39:47 PM
> > > > > > > The sites.xml in /homes/papia/SwiftSCE2 seems to be using
> > > > > > > passive
> > > > > > > persistent coasters. Is there a way to use automatic
> > > > > > > coasters on
> > > > > > > the
> > > > > > > MCS workstations? I'll try copying this over to PADS and
> > > > > > > running
> > > > > > > there
> > > > > > > to see if I can reproduce it.
> > > > > > > David
> > > > > > > > From: "Michael Wilde" <wilde at mcs.anl.gov>
> > > > > > > > "Papia
> > > > > > > > Rizwan" <papia.rizwan at gmail.com>, "Mihael Hategan"
> > > > > > > > Sent: Thursday, September 15, 2011 2:18:17 PM
> > > > > > > > Can you make SWAT run under trunk, as Papia is testing
> > > > > > > > using
> > > > > > > > standard
> > > > > > > > auto coasters, and doesnt need any of the missing
> > > > > > > > coaster-service
> > > > > > > > options.
> > > > > > > > - Mike
> > > > > > > > > "Papia
> > > > > > > > > Sent: Thursday, September 15, 2011 2:15:36 PM
> > > > > > > > > I got past the compilation errors by renaming the all
> > > > > > > > > functions
> > > > > > > > > with
> > > > > > > > > capitalization, but ran into an issue with
> > > > > > > > > coaster-service.
> > > > > > > > > Last
> > > > > > > > > week
> > > > > > > > > I noticed coaster-service was missing options for
> > > > > > > > > dynamic
> > > > > > > > > ports.
> > > > > > > > > I
> > > > > > > > > found today that it is also missing -passive. I'll try
> > > > > > > > > to
> > > > > > > > > track
> > > > > > > > > down
> > > > > > > > > where this changed and restore the previous version.
> > > > > > > > > David
> > > > > > > > > > "Papia
> > > > > > > > > > Sent: Thursday, September 15, 2011 12:37:13 PM
> > > > > > > > > > Excellent, thanks - thats good. I also just verified
> > > > > > > > > > that
> > > > > > > > > > Papia
> > > > > > > > > > is
> > > > > > > > > > not
> > > > > > > > > > using the overAllocation tags in the sites file, so
> > > > > > > > > > this
> > > > > > > > > > problem
> > > > > > > > > > is
> > > > > > > > > > clearly a Java deadlock and has nothing to do with the
> > > > > > > > > > scheduling
> > > > > > > > > > problem that the (now fixed) overAllocation problem
> > > > > > > > > > was
> > > > > > > > > > causing..
> > > > > > > > > > My understanding is that this SWAT script is failing
> > > > > > > > > > under
> > > > > > > > > > trunk
> > > > > > > > > > because of the recent token case handling issue (I
> > > > > > > > > > think
> > > > > > > > > > the
> > > > > > > > > > camel-case one). Can you work with Papia to see if
> > > > > > > > > > either
> > > > > > > > > > that
> > > > > > > > > > issue
> > > > > > > > > > is now fixed, or if her script can be changed to avoid
> > > > > > > > > > that,
> > > > > > > > > > so
> > > > > > > > > > that
> > > > > > > > > > you can both test the SWAT script with trunk, to see
> > > > > > > > > > if
> > > > > > > > > > the
> > > > > > > > > > deadlock
> > > > > > > > > > still occurs?
> > > > > > > > > > Thanks,
> > > > > > > > > > - MIke
> > > > > > > > > > > "Papia
> > > > > > > > > > > Sent: Thursday, September 15, 2011 12:29:03 PM
> > > > > > > > > > > I narrowed down the problem a bit. Last night I ran
> > > > > > > > > > > jstack
> > > > > > > > > > > on
> > > > > > > > > > > the
> > > > > > > > > > > wrong java process which is why it didn't report a
> > > > > > > > > > > deadlock.
> > > > > > > > > > > Papia and I are seeing the same issue.
> > > > > > > > > > > My jstack:
> > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat2/jstack.log
> > > > > > > > > > > Papia's jstack:
> > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat2/papia-jstack.log
> > > > > > > > > > > It happens in the same place:
> > > > > > > > > > > org.griphyn.vdl.karajan.lib.cache.File.lock(File.java:100)
> > > > > > > > > > > org.griphyn.vdl.karajan.lib.cache.LRUFileCache.addAndLockEntry(LRUFileCache.java:24)
> > > > > > > > > > > Filed as bug #559
> > > > > > > > > > > David
> > > > > > > > > > > > "Papia
> > > > > > > > > > > > Sent: Thursday, September 15, 2011 11:46:59 AM
> > > > > > > > > > > > David, it sounds like more analysis is needed
> > > > > > > > > > > > here. If
> > > > > > > > > > > > the
> > > > > > > > > > > > SWAT
> > > > > > > > > > > > runs
> > > > > > > > > > > > are not showing a deadlock (but your runs are)
> > > > > > > > > > > > then
> > > > > > > > > > > > likely
> > > > > > > > > > > > we
> > > > > > > > > > > > have
> > > > > > > > > > > > two
> > > > > > > > > > > > different problems here.
> > > > > > > > > > > > Another case we saw in 0.93 with scripts failing
> > > > > > > > > > > > to
> > > > > > > > > > > > progress
> > > > > > > > > > > > is
> > > > > > > > > > > > due
> > > > > > > > > > > > to
> > > > > > > > > > > > the overAllocation parameter problem that Mihael
> > > > > > > > > > > > fixed
> > > > > > > > > > > > yesterday.
> > > > > > > > > > > > The
> > > > > > > > > > > > symptom there is that Swift starts a coaster with
> > > > > > > > > > > > a
> > > > > > > > > > > > time
> > > > > > > > > > > > slot
> > > > > > > > > > > > too
> > > > > > > > > > > > small for the apps in the script, and no apps wind
> > > > > > > > > > > > up
> > > > > > > > > > > > running.
> > > > > > > > > > > > I
> > > > > > > > > > > > think
> > > > > > > > > > > > that situation in general merits a separate
> > > > > > > > > > > > ticket,
> > > > > > > > > > > > and
> > > > > > > > > > > > may
> > > > > > > > > > > > have
> > > > > > > > > > > > been
> > > > > > > > > > > > discussed on swift-devel (but quite a while ago).
> > > > > > > > > > > > Can you determine if indeed Papia's SWAT runs are
> > > > > > > > > > > > hanging
> > > > > > > > > > > > for
> > > > > > > > > > > > a
> > > > > > > > > > > > reason
> > > > > > > > > > > > other than a Java deadlock?
> > > > > > > > > > > > - Mike
> > > > > > > > > > > > > "Papia
> > > > > > > > > > > > > Hategan"
> > > > > > > > > > > > > Sent: Thursday, September 15, 2011 8:03:09 AM
> > > > > > > > > > > > > The jstack log corresponds to the most recent
> > > > > > > > > > > > > log
> > > > > > > > > > > > > file -
> > > > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat/cce_ua-20110914-1934-frd3thja.log.
> > > > > > > > > > > > > jstack does not report any deadlocks, but I
> > > > > > > > > > > > > thought
> > > > > > > > > > > > > it
> > > > > > > > > > > > > might
> > > > > > > > > > > > > be
> > > > > > > > > > > > > useful
> > > > > > > > > > > > > so I included it. Swift was not making any
> > > > > > > > > > > > > progress
> > > > > > > > > > > > > for
> > > > > > > > > > > > > about
> > > > > > > > > > > > > 5
> > > > > > > > > > > > > hours
> > > > > > > > > > > > > before I sent the logs. I am running the latest
> > > > > > > > > > > > > 0.93
> > > > > > > > > > > > > branch.
> > > > > > > > > > > > > I
> > > > > > > > > > > > > will
> > > > > > > > > > > > > try again today.
> > > > > > > > > > > > > David
> > > > > > > > > > > > > > "Papia
> > > > > > > > > > > > > > Hategan"
> > > > > > > > > > > > > > Sent: Thursday, September 15, 2011 5:54:11 AM
> > > > > > > > > > > > > > David, which of the many Swift logs in that
> > > > > > > > > > > > > > /swat
> > > > > > > > > > > > > > dir
> > > > > > > > > > > > > > does
> > > > > > > > > > > > > > the
> > > > > > > > > > > > > > jstack.log pertain to? How many of these runs
> > > > > > > > > > > > > > deadlocked?
> > > > > > > > > > > > > > And, did you verify that you (and Papia) are
> > > > > > > > > > > > > > running
> > > > > > > > > > > > > > on
> > > > > > > > > > > > > > the
> > > > > > > > > > > > > > latest
> > > > > > > > > > > > > > rev
> > > > > > > > > > > > > > of the 0.93 branch?
> > > > > > > > > > > > > > - Mike
> > > > > > > > > > > > > > > To: "Mihael Hategan" <hategan at mcs.anl.gov>
> > > > > > > > > > > > > > > "Papia
> > > > > > > > > > > > > > > Wilde"
> > > > > > > > > > > > > > > Sent: Wednesday, September 14, 2011 11:04:41
> > > > > > > > > > > > > > > PM
> > > > > > > > > > > > > > > deadlock
> > > > > > > > > > > > > > > I was able to reproduce the problem with
> > > > > > > > > > > > > > > persistent
> > > > > > > > > > > > > > > coasters
> > > > > > > > > > > > > > > on
> > > > > > > > > > > > > > > the
> > > > > > > > > > > > > > > MCS servers.
> > > > > > > > > > > > > > > The jstack output is at
> > > > > > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat/jstack.log
> > > > > > > > > > > > > > > The full collection of logs are at
> > > > > > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat.
> > > > > > > > > > > > > > > David
> > > > > > > > > > > > > > > > "Papia
> > > > > > > > > > > > > > > > 10:30:48
> > > > > > > > > > > > > > > > PM
> > > > > > > > > > > > > > > > deadlock
> > > > > > > > > > > > > > > > Could you also forward the attachments
> > > > > > > > > > > > > > > > please?
> > > > > > > > > > > > > > > > Mihael
> > > > > > > > > > > > > > > > On Wed, 2011-09-14 at 14:46 -0500, Michael
> > > > > > > > > > > > > > > > Wilde
> > > > > > > > > > > > > > > > wrote:
> > > > > > > > > > > > > > > > > I think I am seeing a similar deadlock
> > > > > > > > > > > > > > > > > on
> > > > > > > > > > > > > > > > > 0.93
> > > > > > > > > > > > > > > > > in
> > > > > > > > > > > > > > > > > the
> > > > > > > > > > > > > > > > > ParVis
> > > > > > > > > > > > > > > > > script,
> > > > > > > > > > > > > > > > > and am trying to get a clean log and
> > > > > > > > > > > > > > > > > jstack
> > > > > > > > > > > > > > > > > to
> > > > > > > > > > > > > > > > > confirm.
> > > > > > > > > > > > > > > > > As far as I can tell, Papia is running
> > > > > > > > > > > > > > > > > the
> > > > > > > > > > > > > > > > > correct
> > > > > > > > > > > > > > > > > 0.93
> > > > > > > > > > > > > > > > > code,
> > > > > > > > > > > > > > > > > but
> > > > > > > > > > > > > > > > > please verify.
> > > > > > > > > > > > > > > > > David will try to replicate this problem
> > > > > > > > > > > > > > > > > as
> > > > > > > > > > > > > > > > > well.
> > > > > > > > > > > > > > > > > - Mike
> > > > > > > > > > > > > > > > > > From: "Papia Rizwan"
> > > > > > > > > > > > > > > > > > To: "swift-devel Devel"
> > > > > > > > > > > > > > > > > > "Michael
> > > > > > > > > > > > > > > > > > Wilde" <wilde at mcs.anl.gov>, "Michael
> > > > > > > > > > > > > > > > > > P.
> > > > > > > > > > > > > > > > > > Shields"
> > > > > > > > > > > > > > > > > > <mpshields at anl.gov>
> > > > > > > > > > > > > > > > > > 1:56:13 PM
> > > > > > > > > > > > > > > > > > Subject: swift 0.93 deadlock
> > > > > > > > > > > > > > > > > > Attached are the jstack output and the
> > > > > > > > > > > > > > > > > > log
> > > > > > > > > > > > > > > > > > file.
> > > > > > > > > > > > > > > > > > Papia Rizwan
> > > > > > > > > > > > > > > > _______________________________________________
> > > > > > > > > > > > > > > > Swift-devel mailing list
> > > > > > > > > > > > > > > > Swift-devel at ci.uchicago.edu
> > > > > > > > > > > > > > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > > > > > > > > > > > > > Michael Wilde
> > > > > > > > > > > > > > Computation Institute, University of Chicago
> > > > > > > > > > > > > > Mathematics and Computer Science Division
> > > > > > > > > > > > > > Argonne National Laboratory
> > > > > > > > > > > > Michael Wilde
> > > > > > > > > > Michael Wilde
> > > > > > > > Michael Wilde
