[Swift-devel] swift config error
    Jonathan Monette
    jonmon at mcs.anl.gov
    Tue Sep 20 16:25:44 CDT 2011
I have been getting this error today.
Execution failed:
	Swift config property "wrapperlog.always.transfer" not found in Swift configuration [swift.properties]
Here is my config file:
execution.retries=0
//replication.enabled=true
//replication.limit=3
sitedir.keep=true
status.mode=provider
wrapper.log.always.transfer=true
foreach.maxthreads=1024
wrapper.parameter.mode=files
use.provider.staging=false
provider.staging.pin.swiftfiles=false
The log is located at www.ci.uchicago.edu/~jonmon/logs/montage-20110920-1618-xu597sg2.log
Were some changes made to the properties?
