[Swift-devel] case sensitivity
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Sep 19 14:02:47 CDT 2011
I think toInt is broken in trunk.
I just svn up'ed my trunk and cant seem to get any variant of toint() to work. They all give:
fusion$ cat ti.swift
int i = @toInt("123");
fusion$ swift ti.swift
no sites file specified, setting to default: /homes/wilde/swift/src/trunk/cog/modules/swift/dist/swift-svn/etc/sites.xml
Could not start execution:
        Compile error in assignment at line 2: Unknown function: @toInt:
fusion$
I tried @toint(), @toInt() and toInt().
- Mike
----- Original Message -----
> From: "Michael Wilde" <wilde at mcs.anl.gov>
> To: "Mihael Hategan" <hategan at mcs.anl.gov>
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Monday, September 19, 2011 11:44:12 AM
> Subject: Re: [Swift-devel] case sensitivity
> I feel that backwards compatibility - at least for some length period
> of time, but better yet indefinitely - needs to take priority over
> aesthetic issues.
> So I can see providing and documenting a function like toInt() while
> indefinitely allowing toint(). I agree that we should be consistent is
> using camelCase.
> However, until Yadu's email below I was never aware of any case
> insensitivity in Swift - I always programmed as if all names were case
> sensitive. I didnt pay close attention to the brief list discussion on
> case below. Was there any follow-up discussion?
> Can you summarize what the issues are?
> I believe that Swift should be fully case sensitive for all names, and
> that we should not cause existing user code to break unless the cost
> of such backwards compatibility is much worse than the breakage.
> - Mike
> ----- Forwarded Message -----
> From: "Yadu Nand" <yadudoc1729 at gmail.com>
> To: "Ben Clifford" <benc at hawaga.org.uk>
> Cc: "swift-devel" <swift-devel at ci.uchicago.edu>
> Sent: Tuesday, August 9, 2011 10:01:22 AM
> Subject: Re: [Swift-devel] Overwriting procedures in swift.
> > what happens with case? (and, what *should* happen with case?)
> (int o) f ( int i) {
> o = i;
> (int z) F (int a){
> z = a * 5 ;
> trace ( f (5) , F(5) );
> for the above snippet, trace returns 25, 25.
> So F is overwriting f anyway. I don't think this is right.
> > I think karajan identifiers are case insensitive (?) but this patch
> > looks
> > like it is case-sensitive.
> Fixed it. Please check the new patch attached.
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Monday, September 19, 2011 11:06:17 AM
> > Subject: [Swift-devel] case sensitivity
> > Things have now become truly case sensitive in trunk. Which means
> > that
> > there is a distinction between toint and toInt. I opted for toInt
> > for
> > now. In any event, your scripts may break if they use the wrong
> > capitalization.
> > We should document this, and, before releasing 0.94, decide on the
> > details of the capitalization of various things.
> > Mihael
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Michael Wilde
