[Swift-devel] Integrity of trunk in SVN (was: Re: swift 0.93 deadlock)
    David Kelly
    davidk at ci.uchicago.edu
    Fri Sep 16 15:38:52 CDT 2011
> - its not related to the 0.93 deadlock that is holding back the SWAT
> app, is it?
> (ie not related to that email thread?)
Right, it's not directly related to the deadlock. I mentioned it on that thread because we are now able to test with trunk on the MCS servers.
> - can you trace back how the code got damaged in SVN, and see if
> anything else got similarly back-leveled that we may not yet have
> detected in trunk?
I'll take a look at other commits around that time and see if there is anything else.
> - can you take the action item of resuming nightly automated test
> suite execution on trunk, and period (or even nightly) testing on the
> latest release (to see if the suite catches occasional
> sporadically-occuring bugs)
Automated tests have been running nightly for a few weeks now on 0.93 and trunk.
http://www.ci.uchicago.edu/swift/wwwdev/tests/tests.pl
I will add automatic provider testing to that soon, and clean up the organization a bit.
David
> > From: "David Kelly" <davidk at ci.uchicago.edu>
> > To: "Michael Wilde" <wilde at mcs.anl.gov>
> > Cc: "swift-devel Devel" <swift-devel at ci.uchicago.edu>, "Papia
> > Rizwan" <papia.rizwan at gmail.com>
> > Sent: Thursday, September 15, 2011 6:55:25 PM
> > Subject: Re: [Swift-devel] swift 0.93 deadlock
> > Persistent coasters in trunk is fixed now. I think an older version
> > of
> > coaster-service somehow got checked in, so I ran a reverse merge and
> > resolved the conflicts. I tested on mcs workstations with 1000 cats
> > and all seems well.
> > David
> > > Sent: Thursday, September 15, 2011 4:34:02 PM
> > > I was able to get it running on PADS with trunk. I ran into the
> > > same
> > > issue.
> > > http://www.ci.uchicago.edu/~davidk/swat3/jstack.log
> > > http://www.ci.uchicago.edu/~davidk/swat3/cce_ua-20110915-1617-sd4svyo2.log
> > > David
> > > > Sent: Thursday, September 15, 2011 2:39:47 PM
> > > > The sites.xml in /homes/papia/SwiftSCE2 seems to be using
> > > > passive
> > > > persistent coasters. Is there a way to use automatic coasters on
> > > > the
> > > > MCS workstations? I'll try copying this over to PADS and running
> > > > there
> > > > to see if I can reproduce it.
> > > > David
> > > > > From: "Michael Wilde" <wilde at mcs.anl.gov>
> > > > > To: "David Kelly" <davidk at ci.uchicago.edu>
> > > > > Rizwan" <papia.rizwan at gmail.com>, "Mihael Hategan"
> > > > > <hategan at mcs.anl.gov>
> > > > > Sent: Thursday, September 15, 2011 2:18:17 PM
> > > > > Can you make SWAT run under trunk, as Papia is testing using
> > > > > standard
> > > > > auto coasters, and doesnt need any of the missing
> > > > > coaster-service
> > > > > options.
> > > > > - Mike
> > > > > > "Papia
> > > > > > Sent: Thursday, September 15, 2011 2:15:36 PM
> > > > > > I got past the compilation errors by renaming the all
> > > > > > functions
> > > > > > with
> > > > > > capitalization, but ran into an issue with coaster-service.
> > > > > > Last
> > > > > > week
> > > > > > I noticed coaster-service was missing options for dynamic
> > > > > > ports.
> > > > > > I
> > > > > > found today that it is also missing -passive. I'll try to
> > > > > > track
> > > > > > down
> > > > > > where this changed and restore the previous version.
> > > > > > David
> > > > > > > "Papia
> > > > > > > Sent: Thursday, September 15, 2011 12:37:13 PM
> > > > > > > Excellent, thanks - thats good. I also just verified that
> > > > > > > Papia
> > > > > > > is
> > > > > > > not
> > > > > > > using the overAllocation tags in the sites file, so this
> > > > > > > problem
> > > > > > > is
> > > > > > > clearly a Java deadlock and has nothing to do with the
> > > > > > > scheduling
> > > > > > > problem that the (now fixed) overAllocation problem was
> > > > > > > causing..
> > > > > > > My understanding is that this SWAT script is failing under
> > > > > > > trunk
> > > > > > > because of the recent token case handling issue (I think
> > > > > > > the
> > > > > > > camel-case one). Can you work with Papia to see if either
> > > > > > > that
> > > > > > > issue
> > > > > > > is now fixed, or if her script can be changed to avoid
> > > > > > > that,
> > > > > > > so
> > > > > > > that
> > > > > > > you can both test the SWAT script with trunk, to see if
> > > > > > > the
> > > > > > > deadlock
> > > > > > > still occurs?
> > > > > > > Thanks,
> > > > > > > - MIke
> > > > > > > > "Papia
> > > > > > > > Sent: Thursday, September 15, 2011 12:29:03 PM
> > > > > > > > I narrowed down the problem a bit. Last night I ran
> > > > > > > > jstack
> > > > > > > > on
> > > > > > > > the
> > > > > > > > wrong java process which is why it didn't report a
> > > > > > > > deadlock.
> > > > > > > > Papia and I are seeing the same issue.
> > > > > > > > My jstack:
> > > > > > > > http://www.ci.uchicago.edu/~davidk/swat2/jstack.log
> > > > > > > > Papia's jstack:
> > > > > > > > http://www.ci.uchicago.edu/~davidk/swat2/papia-jstack.log
> > > > > > > > It happens in the same place:
> > > > > > > > org.griphyn.vdl.karajan.lib.cache.File.lock(File.java:100)
> > > > > > > > org.griphyn.vdl.karajan.lib.cache.LRUFileCache.addAndLockEntry(LRUFileCache.java:24)
> > > > > > > > Filed as bug #559
> > > > > > > > David
> > > > > > > > > "Papia
> > > > > > > > > Sent: Thursday, September 15, 2011 11:46:59 AM
> > > > > > > > > David, it sounds like more analysis is needed here. If
> > > > > > > > > the
> > > > > > > > > SWAT
> > > > > > > > > runs
> > > > > > > > > are not showing a deadlock (but your runs are) then
> > > > > > > > > likely
> > > > > > > > > we
> > > > > > > > > have
> > > > > > > > > two
> > > > > > > > > different problems here.
> > > > > > > > > Another case we saw in 0.93 with scripts failing to
> > > > > > > > > progress
> > > > > > > > > is
> > > > > > > > > due
> > > > > > > > > to
> > > > > > > > > the overAllocation parameter problem that Mihael fixed
> > > > > > > > > yesterday.
> > > > > > > > > The
> > > > > > > > > symptom there is that Swift starts a coaster with a
> > > > > > > > > time
> > > > > > > > > slot
> > > > > > > > > too
> > > > > > > > > small for the apps in the script, and no apps wind up
> > > > > > > > > running.
> > > > > > > > > I
> > > > > > > > > think
> > > > > > > > > that situation in general merits a separate ticket,
> > > > > > > > > and
> > > > > > > > > may
> > > > > > > > > have
> > > > > > > > > been
> > > > > > > > > discussed on swift-devel (but quite a while ago).
> > > > > > > > > Can you determine if indeed Papia's SWAT runs are
> > > > > > > > > hanging
> > > > > > > > > for
> > > > > > > > > a
> > > > > > > > > reason
> > > > > > > > > other than a Java deadlock?
> > > > > > > > > - Mike
> > > > > > > > > > "Papia
> > > > > > > > > > Sent: Thursday, September 15, 2011 8:03:09 AM
> > > > > > > > > > The jstack log corresponds to the most recent log
> > > > > > > > > > file
> > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat/cce_ua-20110914-1934-frd3thja.log.
> > > > > > > > > > jstack does not report any deadlocks, but I thought
> > > > > > > > > > it
> > > > > > > > > > might
> > > > > > > > > > be
> > > > > > > > > > useful
> > > > > > > > > > so I included it. Swift was not making any progress
> > > > > > > > > > for
> > > > > > > > > > about
> > > > > > > > > > 5
> > > > > > > > > > hours
> > > > > > > > > > before I sent the logs. I am running the latest 0.93
> > > > > > > > > > branch.
> > > > > > > > > > I
> > > > > > > > > > will
> > > > > > > > > > try again today.
> > > > > > > > > > David
> > > > > > > > > > > "Papia
> > > > > > > > > > > Sent: Thursday, September 15, 2011 5:54:11 AM
> > > > > > > > > > > David, which of the many Swift logs in that /swat
> > > > > > > > > > > dir
> > > > > > > > > > > does
> > > > > > > > > > > the
> > > > > > > > > > > jstack.log pertain to? How many of these runs
> > > > > > > > > > > deadlocked?
> > > > > > > > > > > And, did you verify that you (and Papia) are
> > > > > > > > > > > running
> > > > > > > > > > > on
> > > > > > > > > > > the
> > > > > > > > > > > latest
> > > > > > > > > > > rev
> > > > > > > > > > > of the 0.93 branch?
> > > > > > > > > > > - Mike
> > > > > > > > > > > > To: "Mihael Hategan" <hategan at mcs.anl.gov>
> > > > > > > > > > > > "Papia
> > > > > > > > > > > > Rizwan" <papia.rizwan at gmail.com>, "Michael
> > > > > > > > > > > > Wilde"
> > > > > > > > > > > > Sent: Wednesday, September 14, 2011 11:04:41 PM
> > > > > > > > > > > > I was able to reproduce the problem with
> > > > > > > > > > > > persistent
> > > > > > > > > > > > coasters
> > > > > > > > > > > > on
> > > > > > > > > > > > the
> > > > > > > > > > > > MCS servers.
> > > > > > > > > > > > The jstack output is at
> > > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat/jstack.log
> > > > > > > > > > > > The full collection of logs are at
> > > > > > > > > > > > http://www.ci.uchicago.edu/~davidk/swat.
> > > > > > > > > > > > David
> > > > > > > > > > > > > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > > > > > > > > > > > > "Papia
> > > > > > > > > > > > > Sent: Wednesday, September 14, 2011 10:30:48
> > > > > > > > > > > > > PM
> > > > > > > > > > > > > Could you also forward the attachments please?
> > > > > > > > > > > > > Mihael
> > > > > > > > > > > > > On Wed, 2011-09-14 at 14:46 -0500, Michael
> > > > > > > > > > > > > Wilde
> > > > > > > > > > > > > wrote:
> > > > > > > > > > > > > > I think I am seeing a similar deadlock on
> > > > > > > > > > > > > > 0.93
> > > > > > > > > > > > > > in
> > > > > > > > > > > > > > the
> > > > > > > > > > > > > > ParVis
> > > > > > > > > > > > > > script,
> > > > > > > > > > > > > > and am trying to get a clean log and jstack
> > > > > > > > > > > > > > to
> > > > > > > > > > > > > > confirm.
> > > > > > > > > > > > > > As far as I can tell, Papia is running the
> > > > > > > > > > > > > > correct
> > > > > > > > > > > > > > 0.93
> > > > > > > > > > > > > > code,
> > > > > > > > > > > > > > but
> > > > > > > > > > > > > > please verify.
> > > > > > > > > > > > > > David will try to replicate this problem as
> > > > > > > > > > > > > > well.
> > > > > > > > > > > > > > - Mike
> > > > > > > > > > > > > > > From: "Papia Rizwan"
> > > > > > > > > > > > > > > To: "swift-devel Devel"
> > > > > > > > > > > > > > > "Michael
> > > > > > > > > > > > > > > Wilde" <wilde at mcs.anl.gov>, "Michael P.
> > > > > > > > > > > > > > > Shields"
> > > > > > > > > > > > > > > <mpshields at anl.gov>
> > > > > > > > > > > > > > > 1:56:13
> > > > > > > > > > > > > > > PM
> > > > > > > > > > > > > > > Subject: swift 0.93 deadlock
> > > > > > > > > > > > > > > Attached are the jstack output and the log
> > > > > > > > > > > > > > > file.
> > > > > > > > > > > > > > > Papia Rizwan
> > > > > > > > > > > > > _______________________________________________
> > > > > > > > > > > > > Swift-devel mailing list
> > > > > > > > > > > > > Swift-devel at ci.uchicago.edu
> > > > > > > > > > > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > > > > > > > > > > Michael Wilde
> > > > > > > > > > > Computation Institute, University of Chicago
> > > > > > > > > > > Mathematics and Computer Science Division
> > > > > > > > > > > Argonne National Laboratory
> > > > > > > > > Michael Wilde
> > > > > > > Michael Wilde
> > > > > Michael Wilde
> Michael Wilde
